I am moving house and want to get rid if the remaining parts I have left, some aftermarket gear, some '97 R33 series 2 parts (gtst with less than 75,000km)
Buy the lot/in a bundle and save, open to negotiation, all offers considered, if your in SA come pick up a bargain
For any pics please see the link here: http://www.skylinesaustralia.com/forums/R3....html&hl=pt
Razo shift knob $50
Speco boost guage (mechanical with cup holder, silver 52mm, reads to 30psi) $75
Personal brand 320mm steering wheel (no boss kit)
-complete with horn button (carbon centre), black leather wheel very good condition $75neg
R33 gtst PARTS VARIOUS
Tail lights with covers/globes/wiring $80each ($120 pair)
driver or passenger window $50 each (or $80 pair)
Wiper stalk $30
Doors both driver and passenger (no windows/motors/central locking) $70 each
INTERIOR STUFF
Interior cabin carpet (no rips or stains etc) $100
Handbrake lever/mechanism (leather handle good condition, only has the front part of the cable) $50
Scuff panel for door shell (says "SKYLINE") $60pair
Roof lining $50
Interior lights both $20 ($15 each)
Sunvisors EDIT: $20 the pair as I damaged a clip on passenger side
All interior surround plastics with x3 grab handles $120neg
(ie all of rear + A/B pillars...no centre console/dash etc these already sold)
Seat belts with brackets/bolts $180 the lot (or $100 front/$100 rear)
Cluster plastic surround $20
DOOR PARTS
driver's door handle $30
passenger door handle $30
Rubber seals for door shell L&R $50 ($35 each)
Rubber seal for boot shell $20
Door ajar sensors complete $10pair
OTHER STUFF
Rear reo bar (undamaged) $100
Side skirts damaged see pics $40 pair
Tie rod boots (front) $20pair
Brake booster & manual brake pedal/bracket $70
Rear camber arms $30 pair
Rear traction arms $30 pair
Bonnet lining (with all clips/plugs) $75
Front ABS sensors complete L&R $30 pair
Front wiper motor $20
Rad and A/C clamps $10 all 4
Standard clutch cover and organic clutch plate $50
Want ALL of this gear gone, moving house and can't be bothered carting it down
PM or post here for a repsonse
Will consider selling cheaper in bulk so make an offer, take the whole lot mentioned above for $750 if you want
https://www.sau.com.au/forums/topic/241857-cheap-aftermarket-and-r33-parts/
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
