I am moving house and want to get rid if the remaining parts I have left, some aftermarket gear, some '97 R33 series 2 parts (gtst with less than 75,000km)
Buy the lot/in a bundle and save, open to negotiation, all offers considered, if your in SA come pick up a bargain
For any pics please see the link here: http://www.skylinesaustralia.com/forums/R3....html&hl=pt
Razo shift knob $50
Speco boost guage (mechanical with cup holder, silver 52mm, reads to 30psi) $75
Personal brand 320mm steering wheel (no boss kit)
-complete with horn button (carbon centre), black leather wheel very good condition $75neg
R33 gtst PARTS VARIOUS
Tail lights with covers/globes/wiring $80each ($120 pair)
driver or passenger window $50 each (or $80 pair)
Wiper stalk $30
Doors both driver and passenger (no windows/motors/central locking) $70 each
INTERIOR STUFF
Interior cabin carpet (no rips or stains etc) $100
Handbrake lever/mechanism (leather handle good condition, only has the front part of the cable) $50
Scuff panel for door shell (says "SKYLINE") $60pair
Roof lining $50
Interior lights both $20 ($15 each)
Sunvisors EDIT: $20 the pair as I damaged a clip on passenger side
All interior surround plastics with x3 grab handles $120neg
(ie all of rear + A/B pillars...no centre console/dash etc these already sold)
Seat belts with brackets/bolts $180 the lot (or $100 front/$100 rear)
Cluster plastic surround $20
DOOR PARTS
driver's door handle $30
passenger door handle $30
Rubber seals for door shell L&R $50 ($35 each)
Rubber seal for boot shell $20
Door ajar sensors complete $10pair
OTHER STUFF
Rear reo bar (undamaged) $100
Side skirts damaged see pics $40 pair
Tie rod boots (front) $20pair
Brake booster & manual brake pedal/bracket $70
Rear camber arms $30 pair
Rear traction arms $30 pair
Bonnet lining (with all clips/plugs) $75
Front ABS sensors complete L&R $30 pair
Front wiper motor $20
Rad and A/C clamps $10 all 4
Standard clutch cover and organic clutch plate $50
Want ALL of this gear gone, moving house and can't be bothered carting it down
PM or post here for a repsonse
Will consider selling cheaper in bulk so make an offer, take the whole lot mentioned above for $750 if you want
https://www.sau.com.au/forums/topic/241857-cheap-aftermarket-and-r33-parts/
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
