i have lined the cooler up infront of the car, its obvious where the top bracket bolts to the car..... but have no idea where the brackets at the bottom of the cooler connect to the car??????
has anyone had this delemma before????
and yes i have searched for about 30minutes now for this answer....
https://www.sau.com.au/forums/topic/241866-more-on-just-jap-stealth-cooler/
lol would you like to share them with the rst of us albert????? lol
is it simple or a pain in the ass??? do i have to make up a bracket or something???
The horn bracket in which the top bit of the cooler bolts to isn't directly in the centre of the car but slightly more to the driver's side and because of this, I actually bolted the bottom two brackets first.
One lines up with the bottom AC Fan bracket, and the other lines up with a spare hole (if I remember correctly). This way, the cooler will sit in the centre.
To then support the top bracket of the cooler, I cable-tied it to the hole in which I was going to bolt it to with the use of 5-7 cable-ties.
Dodgy.... BUT effective :P
This, believe it or not, holds the cooler very steady for the time being until I get a new bracket to support.
lol so its not a direct replacement for a skyline lol..... thats deceptive isn't it???? buying it because just jap says theres no hassel installing it..... i hardly call cable ties a direct replacement lol.... things we have to do for more powrer
Lol, you could say that :)
BUT
Then again, we could have also paid an arm and bought an ARC stealth cooler..
Pay peanuts, get monkeys... as most will say. :)
true,,,,, i agree,,,,, but seeing as the arc one is only $100 more expensive and having bought one i still feel riped off lol,,,,, guess you learn as you go.... and i wouldn't have winged if it was $400 which i recon something like this is actually worth.... but as i said earlier, aslong as it works and does the job
hey again Tom
just to clarify. where did you see the ARC version of this for only $100 more?
cause the only one ive found is off Nengun and its $1500. click HERE to see.
and could you post some pics of the cooler? like pics of the things your not happy with?
I was going to go for one of these too, but for some reason, it costs more to ship something from Australia to NZ than it does from Japan, and with exchange rates it was going to come close to 1K, so i grew a sac and bought a Blitz LM too.
AMAZING cooler. so simple to install and set up.
Im pretty sure there was a thread on here with pics of how the cooler fitted and the brackets that needed to be made for the top.
Im curious to know what car they designed the "direct fit" cooler on? As i cant recall anyone having that bracket line up? Whats the story?
With the side ones, not sure if its the same with the Stealth, but the Blitz has a nut and a bolt, and you just stick the bolt through a random hole in the chassy rail. Is it the same with the Stealth?
Can see it here...
