Drift Spec:
Just do a full service on the car your self.
I.e Fuel Filter, Gearbox Oil, Diff Oil.
And Slap a tube of Nulon G70 in the Gearbox and Diff.
You will be amazed how much difference it makes.
Use Castrol VMX80 for the gearbox, with Nulon G70.
Give it a couple hundred kays to work in then feel fourth again.
It should be better.
If the R33's are the same the fill plug is on the passengers side of the gearbox and roughly centered.
The empty plug is also roughly centered and is on the bottom of the gearbox (duh).
Grab your self a length of general garden hose make sure it is clean and dry.
Empty the oil then put the plug back in (duh) before filling :D
Feed the hose from your engine bay under the car following the exhaust and then put the hose in to the fill hole.
Fill her up from your engine bay.
My Gearbox takes roughly 2 ltr's of oil so I would shove 1ltr in then the Nulon G70 then the other ltr.
Castrol VMX80 is very good but if you want they (AutoBarn) will point you in the direction of Mutol Gearbox oil which is very expensive but does basically the same job just probably a little better maybe?!?!?!
Guest Timbo R33
It costs a bitmore than 700-1000 for a rebuild, trust me ya better off paying for a 2nd hand box and using that unless ya car is putting out some serious grunt!! Rebuild with factory parts is $3000 roughly - depends on who is doing it. If ya want one with race parts, I highly suggest you call somebody who does them, lets just say you wont be getting much back from $5000 if ya lucky and getting mates rates!!
Lets jsut say after calling a lot of places around.. Ive decided "box is good!!" :cool:
i just did a service and i used castrol syntrax 75w-90 full synthetic gearbox oil and a tube of nulon G70. the syntrax is a ****loads better than the vmx80 and cost about triple the price. Not as expensive as redline which was way too dear $140 for 1 gallon/ 3.7L. I must say that the box is sooo much smoother now even in the morning. Give it a go you will not regret it.
You guys have proven that additives do work through trial and error. However I was talking to Steve Cramp (Drifty you may want to call him at Manta Racing) and he claimed that it is not a good idea. From memory it was to do with the fact that the synchros require a certain amount of friction to change properly.
I cant remember exactly what he said however Food for thought.
Akira - FYI - The GTS25-t gearset is identical (internally) to the GTR. Obviously the transfer case etc etc aren't there, but strength wise, they're the same.
Double synchro's on 1st->3rd, and only singles on 4th and 5th... 4th seems the most common to go.
You've either got to be a really bad driver (who crunches alot), or have a *****load of power (and wearing slicks) to break one of these suckers...
matt
Originally posted by akira
Has anyone here rebuilt their gearboxes with strengthened gears etc?
Can GTR internals be used and is this is a good idea?
Any info appreciated before my 5 speed box is installed:cool:
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
    • This makes sense. I have 2 so I'll just choose the least favourable child to perform the task.  If all turns to shit, I've still got a spare.  Win-win!
