Got whole engine package up for sale as im swapping to another motor..
RB25DET Gearbox Including 1 piece tail shaft to suit laurel cefiro comes with exedy 5 puk (60%) and standard flywheel $2200 ono
RB25DET Power fc and handcontoller tuned for 320 hp with a to4e $1450 ono
RB25DET Greedy copy inlet manifold includng 80mm throttle body $350 ono
Rb25DET Highflow injector appox (720cc) $200ono
Nismo Fuel Pressure reg $120
RB25DET SER 2 Split fire coil packs 1 year old $400ono
RB25DET Exhaust maniflold, TO4E Turbo, Wastegate and screamer (6 months old) $450ono
RB25DET Head $300ono
Tomei 1.8mm Metal head gasket used once can be used 4 times $150ono
There are cp pistons that are also about 6 months old i will be pulling them out and getting them all checked If in perfect condition $500 they are 20thou over sized.
also the block, crank will be checked and up for sale.
everthing else like wiring, alternator, starter motor and stuff i have forgotten will be for sale. just ask to see if i have it?
Phone only 0408061696
all parts are on gold coast but can take as far as springwood in south brisbane.
https://www.sau.com.au/forums/topic/241923-rb25det-stuff/
RB25DET Exedy 5 puk (60%) and standard flywheel $2200 ono
RB25DET Block, Crank $call
There are cp pistons that are also about 6 months old i will be pulling them out and getting them all checked, If in perfect condition $500 they are 20thou over sized.
Phone/txt only 0408 061 696 PM not working properly
https://www.sau.com.au/forums/topic/241923-rb25det-stuff/#findComment-4226852
    • Is the 650rpm idle on the rb25det neo for stock cars only? I've never had my car before and after tuning it to idle at 650rpm when cold. Always idle's cold around 1100rpm, and then drops to about 900-950rpm. I've heard the r33 gtst's idle there.
    • Series 1 RB25DET 5 speed gearbox, push type, 1st and 2nd gear syncros worn, may need bearings. Comes with quick shift, Tomei gear knob, release fork, bearing carrier, master and slave cylinder. $850. Cusco Super Single clutch,assembly, 225mm, used, comes with a Direct Clutch solid centre 5 puck ceramic clutch plate. $290. RB26 cams used, excellent condition. $280. HDI GT2 intercooler, excellent condition, has 3 inch piping welded to inlet and outlet. $250. All items located in South Eastern Melbourne. Please PM me if interested.
    • Hi all, I’m currently running a str pipe hi low hks exhaust and downpipe. Was wondering if I change out muffler to a titanium one will it change the sound of the exhaust? Plus I have always liked the look of the titanium pipes … anyone have recommendations to one?    side note already have titanium intake pipes.
    • I looked up my other car that is a R33 GTST series 1.5. Anyone able to confirm what a Aero Form Bumper is?     (1G) 2 Door Coupe; (2GK + 11V) RB25DET; (4B) 2WD HICAS; (7F) 5 Speed Manual; (14G) Super Fine Hard Coat; (15U) Large Rear Spoiler + Aero Form Bumper + Rear Wiper (Aero Selection)
    • Ha ha, all good! I've almost caved in and realised I'm buying one.  I know myself well enough by now that I will start chasing ADHD butterflies half way through building it and not finish it so I'm better off spending the extra money buying one instead of making one just so I can get into straight away.  I would very much enjoy making one as fabrication is probably a strength and definitely a passion but I don't want that to be at the detriment to the car I'm ultimately building it for! There's some pretty good ones around for ~$1100 at the moment so I think I'll just go that way.  At the end I sell it or as mentioned, get another project to make further use of it! Thanks gents.
