This is my new 2door r33 gts4 that I purchased last week.
Very happy with the car so far.
Here is a pic for you all to see :thumbsup:
The wheels look terrible as the offset is way off for this car so I am looking for suitable set at the moment :)
All coments/suggestions welcome :rofl:
https://www.sau.com.au/forums/topic/242004-just-thought-i-would-show-you-all/
  • Replies 44
Haha bought the n/a as I'm a 19yr old p plater haha.
Sunroof is pretty awesome I must admit.
I have no idea about the wheels what so ever, I know they are 17" 4x114.3 and the brand is Speedy, offset I am also not sure of because I have no more info on the wheels as I can't seem to find them on Speedy Wheels Australia but I am guessing probably +35.
When it is not hammering down rain I will go outside and check width and measure the offset.
Until then you will have to wait haha.
Thanks for all the comments!
Edit: Forgot to mention, the car has been in Australia since 2003 and I am the second owner here. I decided not to personally import because I felt it was too much hassle unless the car was well worth it.
xox,
Steph.
Edited by MZBLTZ
As with the front seats, when he purchased the car from Japan it had cigarette marks on the seats, he couldn't source the series 2 seats and decided to put in the series 1 seats.
There is a small mark up near the sunroof on the roof lining from a cigarette aswell as one on the drivers door trim although they are the only marks on the interior.
Seats are being changed when I can source a set of series 2.
xox,
Steph.
Edited by MZBLTZ
    • Stock RB fuel pressure is near enough 43.5 psi, so the latency in that table at 31.6 will be close. You can see that 7 or 8 psi equates to about 0.4µs extra latency. So if you wanted to interpolate between the 31.6 and 39.9 psi values you could say you're going up about 2 psi out of those 8, so add about 0.1µs, which is barely worth talking about and is quite possibly wrong because ideally you would fix the latency while running at the appropriate conditions on the dyno, with a wideband sniffing its butt.
    • The pressure, is what you set the fuel pressure to. If you have the factory fuel reg, you'll need to find the factory spec. I don't know it off the top of my head, but someone else might.
    • For others, what GTSBoy states here should be paid attention. Why? Well lots of people play with different engines, and they LOVE to change things like remove AC, or steering pumps etc, and it lends to them needing to move the tensioner too. You want your tensioner, particularly those that are sprung or hydraulically tensioned, to be the first thing after the harmonic balancer, or technically the "last" pulley in the chain. By saying last pulley, I mean look at the direction the crank spins when the engine is running, follow the belt from where the crank is pulling the belt FROM, and keep following that until you're between the last pulley/accessory on the belt and about to reach the crank again, this is the spot where you put the tensioner. This is the area that will always end up with slack. This is worked out exactly the same way for chains too, as the physics is the same for them. The crank pulley is where all the force to drag the belt around comes from. You will never ever get rid of the slack that appears, especially under load. The tensioners job is to keep the belt loose enough when stationary that there shouldn't be out of sync movement in slow movement, and then be tight enough when running, that the belt can't jump off any gear and get damaged. Too tight, bad things happen, too loose, bad things happen. Have a tensioner (mainly sprung/hydraulic one) in the wrong spot, it can't actually do anything about keeping the tension.
    • It was gonna take much longer for the 440cc so I'd thought I'd risk it with the 550cc. They finally arrived and I couldn't wait any longer (I could but I was quite excited after 2 months) and installed them myself. Removed the old injectors, inserted the new and connected everything up. Before starting the car, I tuned the injector size from the factory 270cc to 550cc using Nistune.   This did some of the calculations automatically which catered for the TIM. The latency however did not seem to change. Deatschwerks have the tuning data available for each injector online, and I had a look at it. It has a table which relates to latency according to pressure and voltage (see below image). Nistune requires the 14v value, but I am unsure of which pressure value to look at (my lack of knowledge and experience have something to do with this). The highlighted value is close to my current latency which is 760µs. It is for 14v which makes sense, and the pressure is 31.6 Psi.   I still gave the car a test drive to see how it goes, and honestly it has never felt so powerful before (and some people say the RB20DE is very weak?). I really enjoyed the drive. Side note; The injectors are quite noisy, which someone mentioned before. This does not really bother me however. I will still ask my mechanic to have a look at it and perhaps ask a tuner to fine tune it if they have the knowledge.
    • Also true. But imagine not wanting new injectors? Imagine wanting to use 30 year old injectors?
