This is my new 2door r33 gts4 that I purchased last week.
Very happy with the car so far.
Here is a pic for you all to see :thumbsup:
The wheels look terrible as the offset is way off for this car so I am looking for suitable set at the moment :)
All coments/suggestions welcome :rofl:
https://www.sau.com.au/forums/topic/242004-just-thought-i-would-show-you-all/
  • Replies 44
Haha bought the n/a as I'm a 19yr old p plater haha.
Sunroof is pretty awesome I must admit.
I have no idea about the wheels what so ever, I know they are 17" 4x114.3 and the brand is Speedy, offset I am also not sure of because I have no more info on the wheels as I can't seem to find them on Speedy Wheels Australia but I am guessing probably +35.
When it is not hammering down rain I will go outside and check width and measure the offset.
Until then you will have to wait haha.
Thanks for all the comments!
Edit: Forgot to mention, the car has been in Australia since 2003 and I am the second owner here. I decided not to personally import because I felt it was too much hassle unless the car was well worth it.
xox,
Steph.
Edited by MZBLTZ
As with the front seats, when he purchased the car from Japan it had cigarette marks on the seats, he couldn't source the series 2 seats and decided to put in the series 1 seats.
There is a small mark up near the sunroof on the roof lining from a cigarette aswell as one on the drivers door trim although they are the only marks on the interior.
Seats are being changed when I can source a set of series 2.
xox,
Steph.
Edited by MZBLTZ
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
