  • Replies 435
Posted Images
This is the one I'll eventually be getting. No where to put it at the moment.
My cousin makes them and has offered me one for free :-)
Can get some good deals if anyone is interested. (Mods delete if inapropriate)
Hi all,
What brake setups are people running on there trailers? The one i am in the progress of building now only has cable drums. Will this be enough? The trailer i usually use has Hyd drums. It will be mainly towing my R33 gtst.
There are some very nice setups in here, some better set up then my shed lol.
Cheers.
any more info on prices etc would be great!
cheers
michael
We are running mechanical discs on the front axle. I've never been a fan of hydrolics or electrics. I don't like the hydrolic one because the trailer sits around for too long,,,absorbing tons of water into the system,,,you would need to cover the cylinder as they need a breather hole in the cap to work properly. The electric one is way to un-reliable for my liking,,,I've been down that road years ago and never going back.
Neil.
And at the risk of disagreeing with Neil(:)), I prefer the electric brakes. Biggest problem is you need a controller in any car using it so you can't easily lend it to someone (well maybe thats a plus)
But for useability, the electric ones are adjustable for the load (they lock the wheel on full if the trailer isn't loaded), and you can apply them manually if the trailer is swaying. Mechanical ones are much simpler but are much less smooth to drive with because they make the trailer jerk under light braking (or even just backing off sometimes)
Thanks guys, i might try the mechanical drums and see how they go.
Electric ones sound good but they are super expensive once you get the controller, brake away, and the brakes them self.
I am going to try and have the trailer ready for BS weekend, but i don't like my chances. We just have to build the ramps put the grid in the chassis and wire it up.
I've towed with electric braked trailers - I hate them. And I had the under dash controller in my previous 4WD. Hydraulics are the best setup imo. Those expensive electric brake controller gizmos are just trying to approximate what the hydraulic system does automatically. The amount of braking applied by the trailer is totally dependant on the weight on the trailer and how hard you are stopping. But hydraulics don't need adjusting and won't lock the wheels if you have no load or if over-adjusted. And over or underadjusted electric brakes can be downright dangerous down mountain ranges.
If you store the trailer outside, simply cover the master cylinder resorvoir with a cup or plastic bag to keep moisture out. nothing too difficult about that.
I've never had any jerking at light braking loads or backing off.
I think the cable drums are the worst setup you can choose. the cables and drums all need to be equally adjusted to brake evenly. could get nasty down a wet mountain range if that's not right... And they need the most maintenance as shoes wear and cables stretch.
Drove to Phillip Island and back with a supposed youbeaut electric brake system, it was crap.
No matter how it was adjusted it would not work evenly at variable speeds. Adjust it to work at highway speeds and when you had to slow down through a town the brakes would lock up. Hopeless.
ahh yes but every hire trailer I've ever seen is a deathtrap. They invariably have bent axles so they sway like a bastard when towing. And their brakes are usually shit or not working at all.
only way to get a reliable trailer is to get your own. And then a tow car. And then somewhere to park them both.
unregistered car cars get expensive.
Ryan, yes you need the electric brakes and controller, but you only need break away system if the trailer is over 2t. And that goes for whatever brake system you use. We just use the cheap controller that runs an input from the brake switch (not variable) and has a variable output on the controller itself which keeps it all simple.
Harry....I get the impression you live near mountains lol. I have not had trouble with either electric or mechanical brakes down hills even with 2t loads but my tow car has pretty capable brakes and tyres on it which helps I guess.
kinda. I used to run alot at Morgan Park at Warwick which is the other side of the range. Used to borrow or hire trailers until I got my own and had some bad experiences! locking electric brakes down there in the wet isn't much fun! never had any issues with my hydraulic braked trailer. I've done quite a few trips between Bris and Sydney/Bathurst too and depending on which way you go, there's a few decent hills along the way too.
yep hire trailers suck. they are usually heavy, crap, and half broken.
I busted my car at wakefield park once and had to hire a ute and trailer to get it back. the clowns gave me a crap little manual ute that felt like it had about 40hp, and weighed about 900kg, then gave me a trailer that weighed what seemed like 800odd kg or more and put my 1250kg car on it. great recipe for disaster.
the thing could barely do 90km flat knacker and you had to rev the ring out of 4th to get enough pace up to get into 5th and cruise, otherwise you'd rapidly loose gound in 5th and have to downshift again. any slight incline meant going back to 4th (and I mean slight). I was getting passed by everything and any truck that went past (at 120km, 4mm off my side mirror of course) sent the thing swaying so much it was a fight to keep it on the road at all. then the invariable high wind out of goulburn started and basically the trailer drove me instead of the other way around. it was scary stuff.
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
