  • Replies 435
Posted Images
Thanks nismoman,ill look into them..
The life of a hot dipped gal trailer should be good for at least 25years and longer..
I know surface rust isn't the end of the world,but a gal trailer will have higher resale value and last longer.
Well if I were spending around 5 to 6k I would personally elect to buy a non gal Aussie steel trailer with some nice options. That will outlast a gal china steel trailer.
I see little point in speccing up a china trailer. They're cheap, and they're value Because they're cheap.
That's just me though.
yeah Neil looked into those. too hard to find and they require the specialist mounts on the deck of the trailer.
Dennis was using a very similar tie down system on his little trailer for his clubman. it had rings mounted on the deck (they fold down flush), and a normal ratchet strap went through them and got tied to the front. mspaint explains....
green is the rings in the deck
blue is the tiedown
red is the ratchet on the tiedown
yellow is a ful sik race car
the outline of the car including the roof is all dented because Mark drove it, not because I suck at mspaint
i have those tie downs in mt 23 footer. work perfectly
Whats peoples experience with Torsion axles?
Im looking into building my own car trailer as part of a final year uni project. So far the requirements are a 3.8x2m bed and a maximum load capacity of 1400 kg to carry my own track car (1200 kg supra) and possibly my mates track cars. I've previously been hiring trailers which have weighed around 1 tonne which although the tow car (saab 9000) has towed it without dramas, the aim is to try make this purpose built trailer as light as possible, hopefully around the 4-500 kg range. As such i was looking into single axle trailers but since reading this thread, would seem like a mistake.
as you know i own the same shapoe as you. i built my 23 footer with ids on all 4 wheels and electric brakes on all 4 wheels. but my old trailer was a standard 14footer with cable brakes and break away system and it was towed by my 2006 STR navara. ive now got an amorok. and with this trailer fully loaded it weighs about 3.1t
  • 6 months later...
Resurrecting an old thread for a bit of advice. It's time for me to get a car trailer so I can start running my car to the track in Darwin (some 317k's away on a road that isn't as flat as you would expect) but I've come upon a rather common problem, what car trailer do I buy? I've read through this entire thread and some others, in addition I have talked to a few other mates who have half an idea about trailers but I'm still confused as to which way to go.
The thing's I do know is that I'm not buying second hand (a 600k round trip with an old shitter just doesn't cut it for me), I'm going for a duel axle as I'm moving a 33 gtst and i want to lend this trailer to other mates, I'm going to try my best to find the lightest trailer possible to keep my running costs down in the long run (and to make it easier to move around by hand) and it will have to have an open floor so it may be used as an emergency workbench (eg gearbox drops/dropping sumps/checking out the latest hecktic damage).
The thing's I don't know are just brake types I should go with (electric controlled braking is favorited up in the NT it seems) and the small things like wheel storage, electric winches, nose cones, etc etc.
That all said I recently found a company called Tilta Trailer ( http://www.tiltatrai...le_trailer.html ) whom make a trailer that seems to check a number of box's, but the only information I have of this trailer is what the website says but I was really hoping someone here has some real world experience with this trailer.
So I guess at the end of all this rambling I would like to ask the following questions: Is the Tilta Trailer as handy as it makes it's self out to be? If so would it handle a pretty average 600k round trip every month with 1200kg's sitting on it? Or should I just go for something super simple and just deal with ramps like everyone else?
And as always any extra hints and tips for towing would be appreciated.
Cheers for the feedback 260DET, anything is better then nothing at this stage.
And the mesh tops doesn't concern me too much, i can just stick a few bits of carpet underneath the tires if I'm running around on semi's just to be on the safe side.
Awesome thanks for that info there essay, it's certainly building up my confidence in the pending purchase if a GTR has been getting around on one for so long without drama's.
If you don't mind me asking essay what electric brake setup did you run along with it? And how easy is it to work the air bags on the trailer?
Cheers.
Cheers.
Using Redarc remote set up. Airbags no issue, excellent ride loaded, just don't forget to undo pin allowing trailer to tilt unlike me when I was unloading it at Tru track in Melbourne in front of cafe and the car dropped onto it's CF under tray with rear wheels in the air. Oops
Oh that's just painful to hear. Hopefully i won't have anything bad like that happen during the coming years of transporting my car around, however the same cannot be said for some of my mates who will no doubt be borrowing the trailer at one point or another haha.
And cheers again for the info essay, will be emailing them soon for final prices and shipping probably tomorrow.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
