Has anyone ever had any experience with "Kwikload" trailers?
http://kwikload.com.au/
Check out a short movie clip showing how to load the trailer.
http://kwikload.com.au/clips/KWIKLOAD.wmv
  • Replies 435
Posted Images
Goodwork posting those up Russ, we got a fair bit done yesterday/last night.
Yes the side rails have been lowered 90mm, although the guards have dropped on 50mm, as the new guards will be cut flush to the top of the rails instead of sitting under. We wont have any dramas opening door on this trailer!
Were planning to have some toolboxes mounted up front, as well as a couple of Jerry can holders.
Material for the tyre rack has been ordered, should have that done within a week.
Duncan, any chance of some pics of your chain and D-Shackle setup? Sounds good.
trailers like 31 always need fixing
anyway my new trailer turns out the suspension tryed to remove itself lol doddy old repar job
anyway 3 hours and about about 15 tig rods later ( we have suspension again)
yea baby
basically the centre bracket ripped itself off on both sides and the leafs were just flopping around
should be good for another 12000 km
lol
anyway will add additional brakets to strengthen the part
funny thing is that the trailer towed perfect for the last 3000km
but now its all bouncy and better... also fixed the brakes and its now and even better dream to tow
can do 140
Edited by fatz
I remember these when they were first released, Adam (cant think of his last name) had just got the Ford drift car and one of those trailers. Was a nice piece of gear looked good and easy to get the cars on/off, but that was 5+ years ago now. As for towing they used a landcruiser and said they had no troubles.
Sorry no first hand experiance with them myself.
:laughing-smiley-014: @ signature
  Beer Baron said:
lol @ signature indeed!
You have read it so now I can use it, so look out when I finally get to the track and you have something I like/need :D
Serriously those trailers were a nice piece of kit, however at the time the were way to $$ compared to what else was available.
Yeah, they're pretty expensive... I saw a demo Kwikload trailer advertised on eBay for $7000. Looked the goods though!
What about these ones?
http://www.tiltatrailer.com.au/
I need a light trailer.... 400kg to 500kg.... and it has to be dual axle for stability.
The place that I got mine made at (www.uniquetrailers.com.au) located at Hoxton Park were about to start making aluminium car trailers the week after I picked up mine (red trailer in the pics). I think the cost for them was going to be about $5k but a fair bit lighter than steel.
Hey fellas,
ended up getting a cheap trailer a month or two ago from http://www.positivequalitytrailers.com/
Not flash, but does the job. Going to replace wheels/tires.
also talked to this guy for a bit - made some nice gear... http://www.blstik.com.au/
Michael
I dont have those clearance lights either Neil, infact that trailer looks 99.9% identical to my trailer (I wonder if UniqueTrailers made that and sent it up as they send a truck load up every week).
the guy up there on the sunny coast makes him himself so i guess they are probably built of the same certain plans you buy on ebay and the like! lol
yeah i was thinking about adding some lamps !
Hey Michael I have the exact same trailer. Excellent value for money seems good quality and tow's really well. Just as you said though I will be changing to light truck tyres for extra peice of mind. Other than the tyres i couldn't be happier with it.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
