Paintballing Nov 16
Nightcrawler
 Share
  • Replies 101
cmon we need more SAU people. We will have the minimum number, but there are over 300 SA SAU members - surely more people have to be interested in shooting others in the name of sport?
*hopes steve is coming* :P
transferring deposit now andrew
Edited by craig R33
Andrew there is a Mallala track day (for bikes) coming up on the same day that I'd like to attend, but the race bike might not be ready.
This means I'm 75% in. If I'm not going to be on track, I'll def be in on the SAU Paintball Battle Royale!
Done paintballing before and its hell fun! :P And I just wanna shoot the .... :O
yeah just transfer me the $10 already .... it is not that hard :P
EVERY SAU event has a thousand people say they are coming, but then on the day every excuse under the sun comes up when they don't turn up. By paying a deposit you are 1. giving me a guarantee that we will have minimum numbers, and 2. that you actually turn up.
i can post in here from the comfort of my home. to deposit money i gota somehow cut time out of my day between work and uni and find a bank, get money out, and deposit it. i barely got time for lunch atm with work busy as. just seems too hard for such a simple thing.
Edited by steveP
+1 to what Heslo said .... even my Mum is tech-savvy enough to use internet banking ....
Don't worry mate, if you are 100% in, and I can take your word on that, then you can pay on the day. But, if you say you are coming, and I rely on that, and then you don't rock up, then we are going to have issues.
You may be a man of your word, but like I already stated, it is VERY frustrating for organisers of events to have a ton of people say on the forums yes, yes, yes, but then when it is time for the actual event have everyone pull out like a little bitch with every excuse under the sun. This event is already a good example - where in Eddy's original post there were well over 20 replies of 'yes I am in'- yet currently I have a whole 4 deposits (excluding my bunch of mates) ....
Cmon we need more people too - it is only $25 ffs - that is a $10 discount off the normal price, and you get to go on a 2 way Skyline cruise half way to Victor Harbor as well! I will be cooking up a barbie for lunch also ....
 Share
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
