cmon we need more SAU people. We will have the minimum number, but there are over 300 SA SAU members - surely more people have to be interested in shooting others in the name of sport?
  • Replies 101
*hopes steve is coming* :P
transferring deposit now andrew
Edited by craig R33
Andrew there is a Mallala track day (for bikes) coming up on the same day that I'd like to attend, but the race bike might not be ready.
This means I'm 75% in. If I'm not going to be on track, I'll def be in on the SAU Paintball Battle Royale!
Done paintballing before and its hell fun! :P And I just wanna shoot the .... :O
yeah just transfer me the $10 already .... it is not that hard :P
EVERY SAU event has a thousand people say they are coming, but then on the day every excuse under the sun comes up when they don't turn up. By paying a deposit you are 1. giving me a guarantee that we will have minimum numbers, and 2. that you actually turn up.
i can post in here from the comfort of my home. to deposit money i gota somehow cut time out of my day between work and uni and find a bank, get money out, and deposit it. i barely got time for lunch atm with work busy as. just seems too hard for such a simple thing.
Edited by steveP
+1 to what Heslo said .... even my Mum is tech-savvy enough to use internet banking ....
Don't worry mate, if you are 100% in, and I can take your word on that, then you can pay on the day. But, if you say you are coming, and I rely on that, and then you don't rock up, then we are going to have issues.
You may be a man of your word, but like I already stated, it is VERY frustrating for organisers of events to have a ton of people say on the forums yes, yes, yes, but then when it is time for the actual event have everyone pull out like a little bitch with every excuse under the sun. This event is already a good example - where in Eddy's original post there were well over 20 replies of 'yes I am in'- yet currently I have a whole 4 deposits (excluding my bunch of mates) ....
Cmon we need more people too - it is only $25 ffs - that is a $10 discount off the normal price, and you get to go on a 2 way Skyline cruise half way to Victor Harbor as well! I will be cooking up a barbie for lunch also ....
    • The values for HID colour are also defined ~ see https://www.legislation.gov.au/F2006L02732/latest/text  ~ goto section 3.9 onwards ....
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
