hey guys.. i just bot my r33 shipped over from victoria. its a pretty sleek looking car. (pics attached)
just about to take the car over the pits tomorrow.
just need some advice from any1 that is willing to give me a hand :thumbsup:
just want to know if the following mods will fail the inspection
turbosmart plumback valve, (legal)
turbo timer
tein adjustable coilovers
there is a 450 hp turbo
apexi boost controller
pod filter (secured and covered)
intercooler
just a few things that i'm concerned about. would any1 be able to tell me if the guys at the pits mite reject the car??
thanks guys :)
https://www.sau.com.au/forums/topic/242033-need-help-with-car-inspection-r33/
All of that should be ok, but I don't think your bonnet will pass. You're not supposed to have reverse facing vents. They reckon if there is oil flying up and it comes out the vents it will be all over your windscreen and you can't see lol. Just take it over as is and see what they say.
lolz.. mite screw on the protector thing under the hood before taking it there.. i heard turbo-timers were illegal because it keeps the engine running after the driver has left the car. is that correct??
I've heard that too, but I'm not sure what the pits say. It may be that you can have them but you can't leave your car while its running or something stupid. Just see what they say I guess.
hehe thats what i'm afraid of. worst case scenario i mite have to take out all the mods and just take it over inspection again. hope it doesnt come to that! :thumbsup:
ya 33s had the battery behind the rear seats
that bonnet will most certainly fail
turbo timers are fine as ive never had problems with any of my cars going through
make sure the car has a "self arming" immoboliser as you will require one
coilovers is a bit iffy, some pass some dont
just take it over, get a list of what needs to be done
everyone makes it sound like a anal rape but its really just another inspection/test
good luck!
Depends on what Teins you have.
If they are like superstreet where only the spring seat is height adjustable they may pass it. If its like flex which is double height adjustable they wont pass it.
If i can help you with the suspension at all, just let me know :)
Cheers
If i can help you with the suspension at all, just let me know ;)
Cheers
Off topic.. but CUTE BUNNY! :)
You will need an immobiliser, eastern states cars aren't required to have one, so chances are you don't have one in there yet. So go get one.
If the car is low, it shouldn't be too big of a deal, mine only has 15cm of clearance at the tip of the front bumber and they passed mine without any issues.
Make sure all of your wipers, lights, safety equipment works.
To save you some hassle, just unplug your turbo timer or set it top not have a countdown.
Hide your boost controller away if possible, it shouldn't be a problem, but best to play it safe.
Minimum clearance is 150mm from the lowest part under your car.. I don't think that includes side skirts but it does include exhaust as far as I know.
Required by law is 100mm clearance from the lowest point of the car (sideskirts, bumpers, exhaust or whatever). The only thing that doesnt get included is flexible mud flaps. If they are a solid mud guard such as late model falcons etc these get included.
Also the law states that this clearance is to be had with half a tank of fuel and ALL seating positions filled.
Hope that helps.
Oh and this Avatar was given to me by a Mod of SAUWA....i could change it, but said person will just change it again LOL....that aside, please take my above comments seriously LOL
also
-your tail lights will be illegal.
-Your alloy pedals will be
- and your tint looks pretty black.
Alll really depends on the inspector you get and the pit you go to. As mentioned best to just go over and see what they list.
If i can help you with the suspension at all, just let me know :D
Cheers
thanks for the offer :P appreciate that!..
so this is what happened today.. i took the car as is today first thing in the morning.
wasnt a shock when it failed inspection. surprisingly it wasnt that bad!. the dude wanted me to take the bov (its legal) but the guy wanted me to take it off. the car was too low so that went on the sheet as well. and had to remove the racing pedals. lolz. i took out the pedals, went to a nearby workshop ("kyp" not the friendliest lol) and put in a stock bov. didnt have time to raise suspensions so we tried our luck and maxed out the tyres. the clearance was well above 100mm. i'd say it was atleast 125mm. took it over the pits again and then the guy puts a rod under the car and says that its still low coz the exhaust system is hanging too low. :P .
so i had to run to a friend's work shop (evolution r). the dude took out my exhaust and put a cannon on. now the car will definetly pass but the car is alot more noisy. dont know whats going to happen there. if they say that the car is too noisy, i'm just going to say that its always been like that and i just adjust increased the height using the coilovers. hopefully i can get away with it.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
