i have heard a few ba reports on gt rs turbos.
they are suited to 2.8ltr engine.
a guy in the uk had 2 sets fitted and had problembs low to mid range on an rb26dett.... good to end though.
so i think safest is hks 2530 as they are well known and driveable on the street.
Hi markr34gtr, we have had GTR's with all sorts of turbo's on then. By far the best allround (road, drag & circuit) was the HKS2530's, closely followed by the N1's, then daylight. With 406 fwkw, those 2530's were heaven on a stick, we upgraded to 2540's and the result was so dissappointing, hardly any more max power, lower average power from 4,500 to 8,500 rpm and way more lag.
If I had a 2.6 litre GTR then 2530's would be on it, simple as that.
Went in a 33 GTR just a few weeks ago with 2530 on it and 350rwkw with great driveability etc. Spooled up early and pull right through to 8500.
For me if I was putting 2530 on I would also put motec on it as this will improve drivability, smoothness etc. Also I would mod the transfer case to make the front hook up faster and thus reduce oversteer. Just what I would do.
Mick.
Hi Mark, we use the a 300 rwkw maximum target for a standard R33/34 GTR intercooler. Boost is irrelevant, it the airflow that makes the power.
For a nice drive we find, being AFM based, an Apexi Power FC to be much better than any of the MAP based ECU's (that includes Motec).
R34's don't have the same ATEESA programming as R32's so don't have the same strong oversteer tendancy. If you want otadjust the bias then HKS make an electronic controller for the purpose. But I would not worry about it on R34, its a must on a high power R32 though.
Hope that helps some more
Mark, there are a couple of us over in Perth running 2530's on GTR's, I've got an R33 and a mate has an R32. He's running 2530's with HKS dumps on stock engine, sticj injectors, stock FMIC, with PFC, Bosch 044 and 1.2 bar and is getting 403rwhp. I'm running 2530's and dumps, HKS FMIC, 700cc injector, cam gears, PFC Pro but am awaiting z32 afm's before tuning to 1.3bar.
I changed my FMIC at 280awhp and without changing anything else power rose to 320awhp so I disagree with the 'stock cooler is good for 450hp theory..
Another factor to consider is about 500 - 550 engine hp the internals are going to be under a lot of pain!!!!
But defo go the 2530's, wicked for street....
Cheers
Brett
i agree , sold on 2530s. might sell my r34 intercoller and get hks type r. 600 by 300 by 103...
i have a mines ecu which is set up for hks 2510 and 600cc.
so it should work okay with my 700cc inj and nismo fuel reg.
i know the way to go is apexi pfc but turbos arent cheap.
we can just tune it with the fuel reg for now..
Hi EVLR33, I am very interested in your experiences with changing the intercooler and getting 40 awhp increase at 280 awhp. Did you change anything else? What happened to the boost? You went from a standard R33 GTR intercooler to ? You didn't change the pipework? Same dyno and operator? Same temperature and humidity?
The reason why I am so interested is that I have had a R33 GTR intercooler on the flow bench and it showed no real restriction until 60 lbs of air per minute, which is enough for around 600 bhp. Plus the GMS R32 GTR 's with N1 intercoolers (same as R33) made 620 bhp before CAMS slapped the limiters on them. So there is a far bit of evidence around to support the 300 awkw limit.
Any feedback would be greatly appreciated.
thanks sydneykid i think i will leave the r34 cooler on for a while as my target is 500 to 600hp. so the 1800bucks can by a apexi pfc or something more important to balance the package.
would like 300rwks and 11 sec 1/4 time.
ran a 12.9 at 108mph last month at 1.1bar with the way it is now.
with a crap 2.0 60ft time. have done 1.8s before .
Mark,
I have the Type R HKS cooler, it's awesome... Also speak to Mark Sharp from Bansai Motorsport he's a legend and he's in Qld. I got my turbos off him second hand for a good price and they were virtually brand new.. Also you can get a PFC with Hand controller for around $1300 from places like Nengun and Greenline. I would suggest you also get the HKS Actuators when you get the turbos. A mate put them on his 2530's and they hold 1.1 bar perfect. I'm running stock actuators and my boost drops off and isn't as consistant...
SydneyKid, I was shocked at the result as well. It was done on the same Dyno about 2 weeks apart (temps were not much different). Boost went up slightly but we didn't change it. Nothing else went on the car except the cooler, stock pipes and everything.... Went from a stock R33 cooler to a HKS Type R...
I guess there could have been a problem with my stock cooler but it looked in good nick... A fair bit of oil and crap came out of it when I degreased it that could have affected it I suppose..
Cheers
Brett
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
    • Can confirm previous shop that built my motor had no fking clue about oil control and caused my motor to shit itself after two track days. Current shop, Birrong Automotive, has managed to build me a motor, not to mention, has also let me tune it myself and it has yet to blow up after 7 track days. Great oiling success, yashimash.
