hey all, just curious if i could get some rough prices on spraying a full bodykit, and for spraying a whole car (r33) im still deciding whether i should spray just the kit as im getting a new one, or spraying the whole thing.
if someone could give me some rough prices on both, or some websites for workshops in vic that i can browse that would be great
PS ive tried searching, but no luck.
peace
https://www.sau.com.au/forums/topic/242059-spraying-price/
  • Replies 58
the one at the top of this thread dosent have any websites, i dont really have time during the week to visit all the workshops :)
yes it would be definatly better if i spray the whole car at the same time, but more expencive ;) my current paint job bar a few things here and there is pretty decent. so yea
https://www.sau.com.au/forums/topic/242059-spraying-price/#findComment-4222350
i checked the sticky, only DT panels didn't have a #, everyone else did.
depending where you are, if you're on a budget, DT Panels or Primal Garage (don't have personal experience) - one is east, one is west.
seriously, search harder... panel beaters/spray jobs/body kits, etc... those threads pop up with regularity in the Vic section.
https://www.sau.com.au/forums/topic/242059-spraying-price/#findComment-4223240
... 800-1500 for a full respray + kit. I know some places thats all they charge... but you pay for good work. I'll just say that much.
Micolour will be substantially more than that, but then the work is without fault.
Also where is the kit coming from?
If its a copy kit... A lot of the time it isn't going to fit. There will be work required to make it fit correctly.
Hell even transit can warp body kits etc. So its highly likely.
Id' budget 3k at the bare minimum. If it was my car, i'd be budgeting 5k.
As ive said before... any spray can look good. Its 5-10years later that the really good work shines when the cheaper jobs fail due to poorer materials, prep and so on associated with low cost.
Oh, and most places dont have websites... its hard to quote anything online without seeing the car. Always best to take it for a visual.
Cheers
https://www.sau.com.au/forums/topic/242059-spraying-price/#findComment-4224056
ok, kool thanks guys
and whats ur oppinion on spraying the whole car as apposed to just the kit? i can fix the parts of the car that are damaged easy enough, i just dont want to do the whole car if i dont need to...
https://www.sau.com.au/forums/topic/242059-spraying-price/#findComment-4224179
From the two shops you mentioned, i would recommend DT Panels and not the other one.
Some panel shops create an orange peel effect on your panel. This shows the quality of the work. Experience from many people showed that we shouldn't be too anal about the cost, it is the effort put into the spray painting.
https://www.sau.com.au/forums/topic/242059-spraying-price/#findComment-4224721
lol yea im not going to swap my house for a paint job on my car, if, IF the paint starts to look dodgy after 5 years, ill get another paint job, it will still be under 5k or 10k$
it might look dodgy but maybe i should just get the panels that have the damage on them sprayed? im just afraid the colour will be to different, i mean, the origional paint on the car hasnt faded bugger all, so perhaps im in the good!
PS its not a show car, its my everyday car, there will be stone chips etc, so im not gonna be extremely anal about it, aslong as its a decent job with no paint variations or bodgy paint spraying...
https://www.sau.com.au/forums/topic/242059-spraying-price/#findComment-4224810
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
