they're the same "98 octane" so is it ok to mix petrols?
or just stick to the onoe bp ultimate? :devil:
there is really no difference between BP98, mobil 98, caltex 98, shell 98. the only differences you get is between servos and batches. sometimes any company will have a bad batch, or some contamination, or you are unlucky enough to buy from a servo with low stock (ie getting fuel from the bottom of the tank) or with old stock. but apart from that it doesn't matter one bit really which 98 brand fuel you buy.
spent a week cruising the hinterland behind coffs harbour last year while the old girl did some business there. I had the luxury of a BP, Shell, and a caltex within 5 minutes of where i was staying so i tried them all. The caltex returned the lowest knock reading of them all. Only talking a couple of points and, as has already been pointed out it could just be different batches causing the slight variance But i wouldnt worry about using any of those 3 in a car tuned to 98 fuel.
Edited by FineLine
well unless i got a bad batch i will have to disagree with everyone
My car was tuned with bp ultimate 98, i never got above 12 no matter what i did
I put in some Caltex vortex 98 and my knock values went through the roof at high rpm. I went to 6900rpm and knock when from 6 to 66 in an instant.
Tune was spot on too
i dunno what it is guys...but in my stock r32 gtst before the half line i can get 230kms with bp ultimate...as soon as i change to something like v power i can get about just over 200-210kms at half way?
but yeh don't think there are probs with mixing petrols...the focus, corolla, swift daily drivers in most cases would probably switch from 4 different brand fuels because they would most likely get whatever is close to them at the time of needing fuel.
I use BP98, Mobil 98 and united 98. Find no difference between either of them. Unless your sitting on the freeway doing the exact speed and accelerating up to speed the same you cannot tell the difference. You might floor it harder for longer 3 times more in 1 whole tank of driving.....you might drive for an hour longer in slightly warmer weather which should make it run slightly richer (depending on ecu).
In terms of knock the turn over the servo has plays a big part in the age of the fuel. Try to fill up at servos that a fairly busy.
  • 2 years later...
@llusions lol I've done the same thing. I realised after putting about 20L in, so just stopped and picked up the 98 and waited for the staff to unlock. You'll be fine running even 91 as long as it is in low ratio, ie 10L out of 60L tank, with the rest being 98 but not recommended. A friend in the country says he carries around a bottle of octane booster, for if he's ever stuck with only 91/95 at a station. Obviously you don't want to do it for long, but as long as the knock is minimal you'll be fine.
Brand wise, they all use the same refineries so really doesn't matter.
98 RON fuel is 98 RON fuel regardless, it is refined to the same standards, so there should be no difference in mixing between brands.
It is generally only bad batches that cause inconsistencies in quality, or if your unfortunate enough to go to a station that has its tanks quite low then you may find minor issues in fuel consumption and power to an extent, but usually not to the extent that it can be noticed from a drivers point of view - maybe only a hand controller or similar showing slightly higher/lower knock readings.
Massive (unsafe) differences in knock levels can only be down to using a lower rated fuel ie: 95/93/91, or an EXTREMELY bad batch of 98, which would be rare.
Further to knock levels and such, as a car gets older especially if it gets out of tune, you might need to increase the octane of the fuel. For example 93 to 95, or 95 to 98. Not so applicable to Skylines, but other 'sports' cars have this problem. Anyway, a good $200 tune should fix that, but just bear in mind you can't always use the fuel in the manual/theory, as reality is different.
personally I have had my car tuned on vpower with a result of 267rwkw and then 278rwkw on the same dyno (different day, however the higher power figure was on a MUCH hotter day)
I only run my cars on ultimate or (manildra e85), and was driving my mates 34 the other day and needed to fill up, the only BP around was closed so I was forced to go to shell. as soon as I left the station the engine check light was flashing under high load.
I have also heard that vpower is a 95 octane fuel with an octane booster to acheive 98ron whereas ultimate is refined as a 98ron
also i know of a few tuners that net lower power figures on shell "fuel" when compared to ultimate.
i dont't have any concrete evidence to back up ANY of these claims, but take it how you want ;)
i do NOT use shell
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
