Ok so its a known fact from a past thread that....
BP 98 is the only 98 Octane fuel that is refined to 98 Octane and not refined to 92 or 95 and then boosted by additives.
Caltex Vortex, Shell Optimax and all that other shit is just normal fuel on steroids which in turn means the fuel is less dense and is less economical whilst giving similar performance.
Just buy BP 98 and you will be using the best.
I fang a bottle of pro strength booster into a 3/4 tank of 98 every now and then and I feel a decent increase again. You will notice a better improvement with an octane booster on BP 98 as well.
ive been comparing V power Shell vs Vortex Caltex. noticed better economy with v power. even with a week of spirited driving i returned 12.8km/100 vs ~13.5km/100 on Caltex
Been getting the same results . Vpower has done wonders. Better fuel economy, more responsive and less detonation
Bp is also the bees knees. No critisms of it either.
Edit: Actually, after reading the remaining post, i believe it Just depends on your tune. Mine was with Vpower so go figure I get the best result with shell.
Edited by wedge_r34gtr
  • 5 years later...
Between dyno trials, drive feel and also inspections after running on an old carby powered engine in a separate vehicle ..
Found that for us, Mobil 98RON has always out performed the shell, bp and vortex.
Each to their own with your preferences of course..
But the Mobil fuel has been great. ( now 7 eleven)
Nothing to do with 98RON (off topic!), but back to back driving Sydney to Kiama and back in my R31 with Shell 91RON and Mobil 91RON, Mobil gave me extra 50km hahaha (45L).
I put 20L Caltex 91RON in it once (E10 unfortunately) and the R31 would stall/run rough in cold start. It didn't like BP 91 (E10, ran a bit rough) but liked Mobil E10 (no difference between Mobil 91 and E10, I still wouldn't put E10 in such an old car).
I've put only 98 Mobil in my cars ever since lol.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
