  • 12 years later...
On 17/07/2021 at 5:52 AM, schowdhry said:
hello from the year 2021 blind elk if your still on here i need your help! i have just swapped the rb25 neo into my gts4, all the mechanical work is done but i need help with wiring up the ecu!
@blind_elk
  • 7 months later...
Are you available to chat with about this conversion ??
  • 2 months later...
On 11/16/2008 at 3:16 PM, blind_elk said:
Sorry, but that's rubbish. When I did the swap in mine, it all just swapped over.
This is Rubbish information and basically screwed up my build plans.
RB25DET (Neo) does not use the same AWD oil pan as the RB20.  The Pan's do not swap. Bolt holes are not aligned. I'll have more photos when I pick it up from the shop.
So to be specific as possible, since every thread I find about this information is vague and useless.
1989 GTS-4 Coupe - AWD - Turbo RB20DET 5spd Manual.
Engine  - RB25DET NEO - Stagea - most likely automatic car.
Car in Question
Engine
RB25DET NEO AWD PAN
RB20DET AWD PAN
Did you swap the Ring and Pinion?
How much a PITA Is it to shim the front differential. From what I can tell there is two thrust washer with 6 various sizes each for sides and two washers with almost 10 each options for the pinion depth along with a pinion sleeve that comes in 6 sizes.
There is almost 1.65mm of depth tolerance stacking and with each of these washers/shims running for $5, that's almost $500 to get enough to play whack a mole with setting up the R&P pattern.
That's why I always just give it to my trusted diff guy to put my Frankendiffs back together.
I'm state side, so while I have two great diff shops near by, neither is going to stock GTR/Nissan shims.
On 5/19/2022 at 10:47 PM, GTSBoy said:
No, but they can use whatever shim they have, measure the difference with feeler gauges (or whatever alternative approach they may choose) and then buy appropriate shims as required. Not really any different over here.
Shims are unique to the GTR/Nissan.  A local shop may determine that a longer sleeve is needed, but they are not going to be able to call up NAPA Auto Parts or a Nissan Dealer and pick up a sleeve.
Also, looking at the FSM - it looks like there is a pressed on bearing for the Snub - sooo I doubt any shop is going to have a dummy bearing to get the initial depth without having to press on - press off the bearing a dozen times.
$150/hr experimenting with all this is going to turn into a $2000 shop bill real quick if I went that route.
Le sigh. The shim you want to leave in there may unique to the R200. But I can guarantee you that any decent shop will have OTHER SHIMS THAT WILL FIT, even if they have to bore the inner diameter out or scrape some off the outer diameter, to use as a bloody reference.
It hasn't cost me much to have my trusted diff shop do it.
  • 1 month later...
As you can see the Pan's are completely different. The RB25 pan is a different bolt pattern and the axle tube + differential are mounted forward.  The Axle is nearly touching the oil sump and there is an additional 3 inch gap between the differential flange and the end bellhousing plane.
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
    • Nah. H2S. H2S is "rotten egg gas", which is what is associated with no cat. SO2 is equally nasty, and if you've ever smelt it you'll know all about it. More of a choking, acid in the back of the throat sort of thing. But you can only smell it in a narrow range up to about 1ppm. Above that, it irritates your mucous membranes, but you don't smell it.
