I have a problem with my air con
ive searched for the wiring diagrams and i found a few things but
i really just need to know where all the fuses are for the air con
(obvious answer under the dash)
I know this already.... the question im asking is that if anyone knows if there is any inline fuse's that are hidden somwhere??
i put power to the relay under the hood fuse box (marked A/C) and the aircon worked Perfectly... :D
so i know the fault is somewhere between the head unit and the relay :down:
i checked other fuses under the dash and they seemed ok
i also had the climate control unit replaced so i know that is not the problem :ermm:
Any ideas??? :P
Well you said the fan turned on when you put power to the relay, maybe it has a small leak? I dont think it costs much to get it tested. At least it rules it out :P
Theres a thread on here with all the Skylines service manuals, try there might have a wiring diagram for the A/C..
k ill have a look
still think its a wiring thing maybe its a faulty pressure switch
faulty pressure swith sounds rite... u can bridge the wires to bypss it... and if it turns on, the switch is f**ked or gas is low :) otherwise back to the drawing board
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
    • So I'm confident in saying its TCS thing. My new cluster I never realized didn't even have bulbs in the TCS or Slip slots. Shining a light through the backside that black plate has nothing for it, unlike my original cluster. Looking at the service manual the only thing that stands out is TCS in relation to the vehicle speed, it has nothing to do with turbos. It sadly looks like I may just need to get the appropriate cluster.
