I just put redline (smurfsblood) in and I it was 3.5 quart bottles (3.3 litres approx), but do a search its been covered before many times, in fact I think I looked it up on here to see how many to order.
what oil should i use? im trying to stop my 4th crunching? redline or royal purple? which is the better to use.
Redline did shit all for my crunching gearbox.. absolute waste of money
try a simple gearbox oil change first $30 and see if that fixes it.. Castrol VMX80
btw the gearbox will take around 3.5 - 3.8 litres... You just keep filling until it comes out of the filler hole.. (make sure you undo the filler hole before dumping your old oil)
Ive changed it many times before :P
Edited by MotoMan
Yep just short of 4L.
I tried Castrol VMX80 last time, it worked fine... but I'm thinking of swapping it out with Castrol Syntrax which is the much more expensive fully synthetic product. It's about $30 per 1L bottle at any local auto store.
I filled mine with 3.8l of redline. Only been 250km since the change, so i cant really comment on any difference in crunching/etc (mine doesn't crunch often anyway). Ended up getting it for 22$ a quart :(.
thanx for all the comments guys
yeah i found a fairly cheap supplier with redline stuff
he is doin me 4ltrs delivered for $112 which i thought was ok.
all the auto shops were around $150
going to get oil change done next week as my 4th is just about impossible to change into unless u double/triple clutch it
Just a little update.
dropped the oil this afternoon out of the box
and to my suprise 3 syncro clips stuck the to bung :)
so i aint going to put $150 worth of redline oil in.
i dont know what to do. what are rebuilds worth on these boxes?
Bearings/seals and 4 syncros is around $1500-1600
thats drive in drive out price..
and to my suprise 3 syncro clips stuck the to bung :D
lol... i had this exact same problem, 3 clips stuck to the magnet, must be a common problem on the RB25 boxes?
I got gear crunching in 3rd and especially 4th... Just for the record, I use VMX80 for the gearbox and diff, and in my books its a pretty good oil...
either way, looks like ill have to get a rebuild soon.. ;)
Edited by EVL-R33
    • I did a bit of googling, the color MCM used was Galaxy Grey from House of Kolor. This is actually a colour I picked out about ~10+ years ago (or more). This one is a stock BMW colour, I guess over the years I figured it was smart to get an OEM colour that was pretty common for all of those sensible reasons one can think of..
    • I absolutely love having clean wheels and also totally love cleaning them. Its not as important to me to have a clean car exterior as it is to have clean wheels. So I bought a kit. I generally use different products for my wheels than anything else, so I thought I'd buy a proper kit and bucket to keep it all in. I got this one from Waxit. I also got the CQuartz wheel and plastic ceramic along with a bunch more application micro fibre pads as CQuartz never provide enough.  The kit was good, but as usual the big, long spongey thing didn't fit between my spokes, so I needed to use a detailing brush and a larger brush that I already owned (been doing this forever, the spokes on these wheels are frustrating.) I did a full clean with the wheel cleaner, it has an iron killing product in it, so I found that I could just use the cleaner and nothing else on the wheels. The tyre cleaner and handled brush were awesome. Made cleaning the tyres so easy. Once everything was clean, I decontaminated with isopropyl and applied the ceramic. Two coats. I bought 2 bottles as I have a lot of wheels to do, half of one bottle did two coats on these. The X5 has 20's so I reckon probably 3/4 on that. Then, for possibly the best part, the wheel cleaning kit comes with a tyre black applicator. But, this is possibly the greatest sponge of all time - its a great size, quite stiff and HAS A COVER! When you finish applying the black, you just put the cover back on! This is revolutionary, I normally have to try and find safe places to put my tyre black applicators as they are covered in silicone and tyre crap. Or, you use something which just falls apart. This applicator is the bee's knee's. Get one. It's worth it. The tyre black is also like a cream, its very thick but goes on really thin, its very easy to use with the applicator. Ayway, after a big clean, decontam, ceramic coat and tyre black the wheels went back on and they look awesome.   Thought I'd share.
    • Haha. Good work. I feel some of your pain because I spent a bunch of time under my car over the period too. Probably nowhere near as much as you did. My happiness is similarly improved by obtaining a desired result though. Those side skirts are.....hecking. Very unfriendly for street and hoist. Sounds to me like you've made a cart that needs to be driven up only planks/blocks at a 2 post hoist, rather than trying to get it up onto a 4 poster. It's very pretty, by the way. Somewhat reminiscent of Marty's squid ink on SuperGramps - at least in the photos.
    • Absolute Legend 🍻 After fighting with the scanned ones for the last 10 years this is a God send
    • ATTAKD 356mm Brake Kit for R34 GTT or R33 GTST. Same brake kit as per here from JJ: https://justjap.com/products/attkd-brake-kit-nissan-skyline-r34-99-02?currency=AUD Can confirm these will bolt directly to a R33 GTST with 12mm bolts OR to a R34 GTT (which is what I had) with the supplied bolts and the collets for the 14mm bolt holes in the R34, which are included. Also included is a set of rotors and hats, as well as 2x brake pad sets. 1) DBA XP (street, hills) 2) Forza FR6 (track) These are radial mounted and bolt directly to R33/R34. You will need extended brake lines to avoid them being full stretch on lock - this is common for all BBK's with the bolt point being in the center. In my case I welded another stud about 25mm lower than the OEM one and retained stock lines and fittings. You'll want a BM57 BMC to get the most out of these. I speak from experience. $1800 (neg for SAU people), located SE Suburbs Melbourne.
