Basically, me n my mate both drive skylines, both just recently bought them and we both love them
now lastnite, he came over and parked across my drive way, we decided to go 4 a cruise, so i backed my car out of my garage right into the back right quater of his car... he was parked on the wrong side of the road and across my driveway...
we are both p platers right, and young, my excess in $1800. and i dont exactlly roll in the cash
should i ask him to help me pay 4 my excess if he was illegally parked at the time?
and im not keen on loosing a friendship as he is my best mate...
my car wasnt really damaged afew scrates etc, im nt worried bout my car.. just his, as his got all the damage, rear bumper hanging off and a dent probly 500mm long 300 high..
what shuld i do???
Edited by gbangaR32
https://www.sau.com.au/forums/topic/242185-i-crashd-in2-my-mates-car/
  • Replies 56
basically it was ur fault
his car was parked and stationary at the time... whether he was park illegally at the time is besides the point.
u probably can get it fix for less then 1800... just go get some quotes.
find out how much it will cost you, i knocked into an old ladies car and paid for mine and hers to get fixed and it was cheaper than bringing the insurance into it. it just depends how bad the damage is i suppose.
you are talking about fixing the damage to his car or just worrying about fixing yours ? u should be fixing his b4 urs you hit it you did the damage you should have been watching where you was going ..
as said above dont tell your insurance just yet and go 2 a few different repairers and get sum quotes on cash jobs fixing it. do u have photos of the damage for people 2 give beter jugement
^^^+1 Absolutely correct!
...anyone reversing is majorly at fault too.
go get some driving lessons faget
Get some English lessons! and keep your comments to yourself.
You have nothing constructive to say!!
Michael, as already stated get some quotes before involving insurance..
if you can work out an agreement between you it may be better off in the long run.
making an insurance claim can increase your premiums for years.
Help get your mates fixed then he can help with yours and all good!!
I guess you both get to learn a lesson here..
A couple months ago my brother did very similar and hit my front guard,
he just gave me what his excess was and I fixed it myself and got better guards. :P
cost him $900 and me $300..
If i remember right.. you had a thread on here about failing your licence.. and then another about doing handbrakies... sounds like your the one needin driving lessons... or a VN commodore
when you reverse tyrone things come from behind...
sorry couldn't help it. anyway I think you will be best off not claiming anthing under about $5,000. so if the damage bill to both cars is > or = $5,000 then make the claim. otherwise just pay to fix it.
Bahahhaha @ BB!
Was it a funny angle?
I vote both of you boys pick up your dignity and work through it.
Get quotes, see what parts you can source yourself, see what work you can do yourselfs and.. and shitty as it my be for your mate, go 50/50 in everything. Im sure he will inderstand.
How bad is the damage? Complete pannel change or just a dent?
If you ask for money from your BEST MATE for this you are not really a mate you are dog/snake. (you f**ked up just pay for it)
I bet you didn't really worry about him "illegally parking" in front of your driveway before you hit his car.
If i were you i would go around getting quotes to get your mates car fixed ASAP.
Best Mate pfft seems like you throw that term around very loosely.
Edited by nismo 400 R N1
yeh honestly, i dont think you can ask your mate to help pay. why didnt you see his car? you cant just assume that no-one will park there and you can just reverse out, you still have to look where your going...
plain and simple buddy but you gotta cough up the cash - if you can source any parts second hand im sure your mate will be there to give you a hand fixing it but your going to have to get it preped and sprayed by a pro.
    • Try looking at Eibacb/H&R springs Thats what Gary sourced for mine.
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
