I've been offered a Mongoose exhaust from a 180SX (well UK 200SX) S13 with the CA engine, and would like to fit it to my A31 Ceffy. It consists of everything from the end of the turbo elbow.
I realise that this isn't going to bolt straight on, but I'm hoping that at the very least the downpipe and the silencer will go straight on. Any idea how much work is going to be involved in getting the centre section to fit. Does it take the same route under the car (I believe the A31 and S13 chassis' are closely related) in which case I'd just have to chop it in half and weld in a bit of pipe of a suitable length.
I'd rather use the Mongoose than go to Powerflow and get a custom one made up as Powerflow generally target the chav (Bogan in Oz?) market, creating gigantic fart cannons that aren't always tuned particularly well, wheras the Mongoose will be reasonably discrete and is known to work well (on CAs at least)
Also if you think this is a stupid idea and I should do something else, please tell me! :P
https://www.sau.com.au/forums/topic/242240-will-an-s13-exhaust-fit-an-a31/
nothing will fit, mate. tried it.
Downpipe flange has to be rewelded. Catalitic converter flange is also different angle.
Silencer is wrong. Nohting will fit without mods. A31 have tire well there. And silencer hangers are different to s or r chassis.
Thanks for that.
So my next question is, what exhaust can I get?
Given the rarity of Ceffy's in the UK, I guess it's going to be a custom jobbie? A shame as I like the twin exhaust look of the Mongoose (basically a bigger bore version of the standard S13 twin peashooters)
Aftermarket cefiro exhausts are very simple, mine only has 1 bend from the cat back and it's only a very small angle (like 10-15 degrees).
It still sits very high off the ground even with a mid muffler, alot better than most examples you see on S13/R32.
If you can't find one at an import parts shop, I'd suggest getting an exhaust shop to make one to fit, rather than trying to make an S13/R32 one fit.
Not to mention the cefiro/laurel has a longer body than the S13/R32.
Laurel parts are interchangeable with cefiros in case you didn't know.
Here is a catback I have in my garage, as you can see it only has 1 bend in it.
The exhaust I have on my car at the moment has a proper oval muffler in position of that resonator thing, and instead of the cannon it has twin pipes.
The other exhaust (currently on car), you can see there is plenty of room for the muffler to sit nice and high. I've pointed to the cat converter and front pipe, just for reference.
Edited by daisu
I have no intention of keeping a cat on this car as there's no legal requirement for me to do so. Cats reduce fuel efficiency anyway and we're constantly told how bad CO2 is :) I was looking at a turbo back system
For a turbo back, use R32 dump pipe (RB20), you'll need a custom front pipe unless you can source a cefiro/laurel aftermarket from jap import shops.
As for the cat, just replace it with a piece of pipe, or if you are getting your catback system made at an exhaust shop, just have them make it longer to meet the front pipe.
Having a bit of language difficulty here. I'm guessing by dump pipe you're refering to the bit immediately after the turbo elbow? I'd call it the downpipe.
No idea what a front pipe is, sorry.
Edit: A bit of googling and looking at pictures of bits of exhaust on Australian parts websites, and I'm now guessing dump pipe = turbo elbow and front pipe = downpipe?
Edited by Lum
  • 1 month later...
Any idea if KTS exhausts are any good?
Looking at the dump/front pipe from here then get the rest custom build locally. Does this seem like a good plan or should I get the entire thing built custom?
hey mate , i build custom exhausts for a living ( sister lives in wales too lol but im stuck in aus ) . if you can source the front pipe easily then do it . off the shelf will always be cheaper than custom made . custom stuff is needed for when your car is modified or rare . source the front pipe and then get the rest custom made . either that or try to source a complete exhaust from japan to suit . seeing as you dont need to run a cat in the u.k you may have some luck getting one off a race car
kermit
kermit
Thanks for that. Problem with getting stuff from Japan is the cost of postage, plus the pound isn't doing very well right now plug all the decent Japanese makes are really expensive anyway. Do the pics of those KTS parts look like they're decently made or do you think I should avoid them and find something else?
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
