Sponsor or not, the rules of the forum apply to everyone, including those about spamming.
That said, I wouldn't consider this a spam thread, as it is genuinely informational (although since its about a particular product, the link dropping is kinda inevitable).
Keep up the good work, congrats on the television coverage, and thanks for your support.
Hi funkymonkey,
Yes I don't consider this a spam thread either, which is why I posted it in the general automotive discussion section rather than the parts for sale section.
Thanks for your kind words - the Skylines Australia forum is definitely one of the best forums out there, and we're more than happy to be an ongoing sponsor of the forum. The forum members on here are very knowledgable and seem to really appreciate the advantages of genuine, real deal JDM parts, so this forum is a very good fit for us.
- Adam
while we are talking about quick release kits.....I need to run a momentary up/down switch on the wheel for attessa settings but want to use a quick release. what's the best way to do it? Bell website mentions some options but there isn't really enough detail.
How many race cars internationally run MoTeC ECUs as well? :( The "JDM yo" 350Zs in Tokyo Drift were running APS twin turbo kits.
Seeing Japanese parts on Aussie cars is happening a bit more these days. I was reading in Motor recently, and Herrod's demo ute runs Tein suspension.
Hi Scathing - I didn't know you were on this forum too :)
Yeah you're exactly right about Aussie parts on cars overseas. I didn't know they run Tein gear on the Herrod's ute - interesting. We are thinking of adapting some Tein gear for use on our Time Attack car - I don't think Tein makes an off the shelf kit for a '71 911 :)
- Adam
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
