It's really wierd. At night when it's warmish the car runs fine. But in the morning when the air is cold it gets up to about 5psi and the boost keeps rising but the car feels like it is running retarded. It doesn't missfire or anything like that it just feel like it has lost a huge amoutn of power. But it only happens when you try and rev it a bit. Crusing is fine. Any idea's?
my car had same problems - mechanic said these are the causes
fuel pump
spark plugs
injectors
fuel filter
one of them is dirty.. hope that helps!
i changed my injectors since i was upgrading anyway.. and it worked perfect
Edited by Tomei_32
Yea stock ECU running a haltech intercepter.
I might have to do some reading on R&R.
But ran the car again tonight and didn't miss a beat.....
So its just the cold air thats causing problems
Well i took it for a drive last night and it played up again. at about 6psi it would feel like the car is retarding and then the boost would spike up.... but this also happens with the boost controller off too so i dont think that the problem. I stoped it and let it sit for about 30 minutes. Straight away it didn't miss a beat for the rest of the night....
Ok this is becoming anoying, it seams that if i leave the car sit overnight or through most of the day it will run shocking as it his about 5 psi. if i drive it and then let it sit for 10 minutes it will run perfect from then on untill it's left for a few hours again. Any idea's?
whats R&R?
I have the same prob. my car feels funny when its cold. Its smooth but its like it doesnt feel quick.
But when its warm and the weather is sunny it feels really nice and sweet.
I thought it was just me. i just services my car recently. it was a major service.
Yea i think it's the AFM, i have cleaned it, i have replaced the fuel filter, spark plugs. i plan to change the fuel pump and i have bought a Z32 AFM. So i hope i can get this sorted soon. The other thing it does when it plays up, if you rev it out and keep the revs there it will missfire.
you cant put an z32 on a stock ecu..
sounds lik R&R to me..ive got the same problem..wen could or hot...
i got a afc neo(untuned)..to try lean out my fuel abit..
so i drop the fuel from about 4000-6000rpm..wen R&Rs kick in..
and dependin on wat boost ur running too..
this was mention by SydneyKid
"It has been my experience that RB25's run a little lean down low in the rpm range (Nissan do this for fuel economy and emissions) and a lot rich up high (Nissan do this to protect the engine). So I have to increase the voltage (using the SAFC) up to around 3,000 rpm and decrease the voltage over 5,000 rpm.
The real problem is in the 3,000 to 5,000 rpm range as the engine comes on boost. They really need lots of fuel very quickly in this area. This can mean that you need to increase the voltage (that the ecu sees) over 5.1 volts to get the right A/F ratios. The ecu then goes into engine protection mode, rich and retarded (sounds like a girl I knew once). Past that rpm you can start leaning it out as it runs too rich, so the voltage needs to be turned down under 5.1 volts. The ecu sees this as the engine not needing protection mode any more, no more rich and retarded.
So you get good performance up to 3,000 rpm, then sluggish from 3,000 rpm to 5,000 rpm and then good performance from 5,000 rpm and over. The SAFC may not help this, in fact as explained above, it can in fact make it worse if the tuner is not switched on to this stuff.
With bent afm voltages, the ecu (tricked by the SAFC) also fires the ignition to suite the airflow it THINKS the engine is getting. This is not a good thing as you generally end up with ignition that is too far advanced in some rpm ranges.
The poor tuner has to juggle the SAFC settings, so that the A/F ratios are OK, the ecu doesn't get into rich and retard (engine protection) mode and the ignition timing is not too far advanced so as to cause detonation. My experience (I am not a good tuner) has been that this is full of compromises, sometimes you just can't win and have to reduce the boost level a bit to get even a reasonable compromise.
Keep in mind that this explanation is very simplified to make it fit in a reasonable space, the rpm's used are rough guides only and every car is different. "
but ur answer is aftermarket ecu...
but wat mods u got?
but check the obvious lik plug gapping..clean ur afm with some good electrical cleaner...coil-packs?
hope this helps...
  • 3 weeks later...
I found today that drove it untill the car warmed up. Only a few minutes. and it was playing up as usuall. Then turned the car off for 15 seconds. Started it up and the problem was gone...... Still confused.
  • 1 year later...
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
