alright guys got my radiator last night as my last one shit itself. would really like to know how to replace the radiator in my r32 gtst myself as i'm low on funds and don't wana drive my car to my mechanic with a bone dry cooling system.
is it simple? i'm a noob..lolz...have a few tools and stuff. it looks pretty straight forward but i haven't had any experience with it so would like to go by a guide. so if someone is nice enough to right a step by step process for me(with pictures if possible :)) i would really appreciate it. Also interested to know the process of filling the system with coolant because a few people ahve told me to do a few things like turn on the heater before you fill up the radiator.
filling up with tectaloy 90plus. this stuff good? will a 5 litre bottle do the job for both radiator and overflow? any help appreciated!
thanks guys!
https://www.sau.com.au/forums/topic/242312-diy-replace-radiator-for-r32-gtst/
I've done it myself and i'm not that crash hot with cars:
Drain fluids and take off hoses, unclip bottom fan shroud (from underneath) undo bolts up top, disconnect the little temp sensor down the left side and it should just lift out, then reverse for reinstalling, might take a bit of shaking if it's a thicker one than standard.. Also theres a bolt you'll need to undo should be on the left side of the engine, and have a little arrow pointing to it cuationing you against opening when hot, it's the air release so you can fill it up properly.. You'll have to let car warm up a bit and wait till water comes out the air release, then seal it and fill up the radiator some more.. hope that helps.. also from memory the tectaloy is like $20 a bottle right? If it is then it's the stuff that will mix with any other fluid so you don't worry about that.. some of the cheap stuff doesn't mix well, can carode stuff
Edited by GTAAAH
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
    • Good news mate, plenty of spares available 5:40
