Done about 15k
Immaculate condition
removed from engine as i'm parting out the car
oiled and bagged to prevent rust, and in original boxes
Adjustable exhaust cam gear is an unknown brand (looks to be a modified stock gear) but has been in the car for 3 years and never slipped.
Looking for $650 pick up in sydney. Happy to post if buyer pays postage.
These are drop in cams and do not require valve spring upgrades.
pics taken during removal to show the lack of marks on the lobes.
cheers
Dave
https://www.sau.com.au/forums/topic/242368-hks-camshafts-rb25det-early/
Im interested ! Approx how much power did these cams make on your Rb25 ?
Sorry mate, they are as good as sold.
Fir interests sake though, went from 238rwkw to 268rwkw with no other changes
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
