Does anyone know a direct avenue to sourcing flares for my C210 coupe. You look at these old school dattos' in Japan and every second car has got them. Surely some import company can source these and post them to Aus, or is it just to smaller item for them to care about. Does anyone know a ph. number of someone who makes them here in Aus? Yours desperately Ricky. I'll even pay a finders fee if someone (private, not a business) can put me onto something solid, but they must be for the C210 coupe
https://www.sau.com.au/forums/topic/242383-there-must-be-an-avenue/
Hey mate,
Check out this place. They definitely have them, however not too cheap.
A few years back when i was looking into it, I was getting help from a guy called Jesse (streeter on these forums) who lives in Japan and organised parts back to Aus.
http://www.kameariengineworks.co.jp/CONTENTS.htm
This page for an example. No C210 flares pictured, but pretty sure they had them back then.
http://www.kameariengineworks.co.jp/catalogue-P50.pdf
About 4 weeks ago I sent an email to the Kameari web site. I've just had an email from Shigeo Mori telling me he can supply the items I'm after BUT! it says:
Overfender for GC 210 %%%%%
Overseas speed mail %%%%%
Total %%%%% These percent icons on my email are actually those little squares you get on Jap web pages. I'm guessing the amounts must be in Japanese and not translating in the email. Help!!!
I take it you are using Windows XP / Vista, is the Japanese Language installed ?
Control Panel / Regional & Language Options / Languages TAB / Details / Add / Pick out of list
Not sure if this will fix your problem, but I don't think it will make it any worse.
Nigel
This was a few years back, but found the quote i got from the Jesse for the C210 flares.
Just a quick breakdown, but obviously things would have changed.
part 31500
bank fee to pay seller 500
ship to me ~1000
commission 3000
ship to you via EMS ~8200(guessing 5kg packed)
total : 44,200yen or ~$490 AUD
Firstly, thanks for your help so far guys. I'm slowly closing the gap to these parts. I got another email from Shigeo Mori at kamaeari today asking if I needed the pricing in AUS dollars,even if it does cost $490 I'm going to get them as they really change the look of the cars stance.
Noddle, I'll try what you've mentioned as like you say, can't do any harm. Cheers
Finally I've ordered my flared gaurds. Cost, $520 dollars delivered. Hopefully they turn up next week. Will post a pic once attached. Brouhgt them off Kamaeri, must say a big thanks to Nismo for the link to Kamaeri.
  • 3 weeks later...
My flared guards arrived today from Japan and and I must say I'm very happy with them. Not sure how I'm going to fix them to the car yet and I may paint them black, currently white. I just like that black against white look. Any suggestions?
hey man that's great news! i want to do this to my 210 coupe so bad. mine's orange and i was gunna go with black guards too.
i reckon black guards on a white skyline look sick as bro you should defo do that :D
hot hot hot.
out of curiosity how much did it cost you all up to get them?
Racsov, they were $510 delivered. Once sent they only took 4 days to arrive. These are made to order. When I asked Shigeo at Kamaeri about the air dam he told me he was having some made up so they'd be a shelf item, cost, about $600 delivered.
Have you thought about getting a mold made of the flares? could be a good little earner :)
Metallic green + charcoal flares + fat charcoal watanabes = :whoops:
just an idea
By the way, car looks awesome mate
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
