There Must Be An Avenue
Wow the costs have really inflated!!
I bought the Front Air Dam about 12 months ago for about $280.00 but had my son who is cabin crew with Qantas bring it back for me.
Hope you will post the piccies when it is all finished.
Does anybody know of a generic rear wing, with a stop light built in, that would fit onto the Coupe Boot???
I would like something that is not over the top. Any suggestions would be appreciated.
Have seen the ducktail from a Torana on this site and it looks a bit Twee to me was thinking of something like simple like the early Silvias and I just wanted the stop ligh for additional safety. Too many over 70 drivers in Adelaide that dont pick up stop light too quickly.
Appreciate the thoughts though racesov!
  • 1 year later...
  • 1 month later...
  • 1 month later...
Hi all, got my car back from engine builder the other day. I now have the heavily ported Brock heads, Edlebrock Performer manifold and a H226 crane cam that makes the car sound like a drag car. I'm very pleased with the outcome as it's still very streetable and it revs nicely with those Yella Terra roller rockers. The heads had to be shaved 100 thou to get compression up as the bottom end is stock 308. in time I'll rebuild it with flat tops and get comp up to about 10;1. Feel like I should be writing this on Aussie V8 website. I'm going to do another vid for utube soon if anyone interested.
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
