Another of my posts refers to noise the front upper portion of the engine is producing.
I thought it was the lifters but after seeing how the cam will move while the gear and VCT housing does not, indicates that something is not correct. I checked for similar cam movement on a spare engine and its quite solid and will not move in relation to the VCT housing.
I'm curious to its internal workings to help me discern what went wrong with it. I plan on tearing off the front of the engine to swap the VCT system starting tomorrow.
When you are referring to the VCT housing moving seperate to the camshaft, if you are saying that the VCT cam pulley moves while the cam remains still...that is not supposed to happen. Check to make sure you don't have a snapped cam first by removing the cam covers and then check the locking bolts in the back of the VCT cam pulley. There is adjustment there and if the locking bolts have loosened, it will be able to move 10 degrees or so but that's about it.
I removed the timing cover to check condition and tension of the belt, which is Nismo and has about 12000Km on it. I also pulled the cam covers to verify the torque on the bearing caps and to look for obvious wear indicators. Everything looks normal.
The cam will move and the gear/VCT does not because it is being held in place by the belt. I tried to reproduce the "failure" on the spare engine (VCT is still attached and cam in the engine) by holding the gear/VCT with a strap wrench and trying to move the cam. It appears to be locked and solid.
I don't know exactly how the VCT mechanism works so I can't fathom what is malfunctioning. Based on the picture, the return spring, helical gear or piston may be broken.
After the swap, I will disassemble and post pictures of the suspected bad VCT.
if the cams moves then there is something wrong with the cam....the VCT doesnt hold the cam in....it only keeps it only tells the computer the degree of the cam, and changes it a small amount through the rpm range.
as Elite man said remove the cam cover and check the cam.
With the timing and cam/valve/rocker covers off, I can physically rotate the camshaft (advance/retard a few degrees) while both cam gears, belt, exhaust cam and crank do not rotate.
The engine starts, runs and boosts just fine. I have oil pressure and knock readings are within normal operating parameters.
Based on grinding noise when cold, tapping noise upon VCT actuation when hot and a spare engine not exhibiting the advance/retard movements, unless the intake cam knock pin/keyway broke, I suspect the VCT device is defective.
Pulled off the suspected bad VCT unit, the cam is not damaged.
No visual external damage to the VCT and the 4 bolts holding the gear were tight.
The VCT appears to be a sealed unit, but I didn't have much time to look at it because the shop closed.
I will finish installing the known good VCT this afternoon.
As for the mechanics, 3 certified ones work at the auto hobby shop where I built the engine and do all the work. They agree with my diagnosis.
I'll try to gain access to the VCT internals. I may call in a favor and have the unit X-rayed.
Original VCT was malfunctioning. Known good VCT installed, bad noises stopped and engine runs smoother.
I will cut apart or x-ray the old one and post the pictures in the near future.
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
