Another of my posts refers to noise the front upper portion of the engine is producing.
I thought it was the lifters but after seeing how the cam will move while the gear and VCT housing does not, indicates that something is not correct. I checked for similar cam movement on a spare engine and its quite solid and will not move in relation to the VCT housing.
I'm curious to its internal workings to help me discern what went wrong with it. I plan on tearing off the front of the engine to swap the VCT system starting tomorrow.
When you are referring to the VCT housing moving seperate to the camshaft, if you are saying that the VCT cam pulley moves while the cam remains still...that is not supposed to happen. Check to make sure you don't have a snapped cam first by removing the cam covers and then check the locking bolts in the back of the VCT cam pulley. There is adjustment there and if the locking bolts have loosened, it will be able to move 10 degrees or so but that's about it.
I removed the timing cover to check condition and tension of the belt, which is Nismo and has about 12000Km on it. I also pulled the cam covers to verify the torque on the bearing caps and to look for obvious wear indicators. Everything looks normal.
The cam will move and the gear/VCT does not because it is being held in place by the belt. I tried to reproduce the "failure" on the spare engine (VCT is still attached and cam in the engine) by holding the gear/VCT with a strap wrench and trying to move the cam. It appears to be locked and solid.
I don't know exactly how the VCT mechanism works so I can't fathom what is malfunctioning. Based on the picture, the return spring, helical gear or piston may be broken.
After the swap, I will disassemble and post pictures of the suspected bad VCT.
if the cams moves then there is something wrong with the cam....the VCT doesnt hold the cam in....it only keeps it only tells the computer the degree of the cam, and changes it a small amount through the rpm range.
as Elite man said remove the cam cover and check the cam.
With the timing and cam/valve/rocker covers off, I can physically rotate the camshaft (advance/retard a few degrees) while both cam gears, belt, exhaust cam and crank do not rotate.
The engine starts, runs and boosts just fine. I have oil pressure and knock readings are within normal operating parameters.
Based on grinding noise when cold, tapping noise upon VCT actuation when hot and a spare engine not exhibiting the advance/retard movements, unless the intake cam knock pin/keyway broke, I suspect the VCT device is defective.
Pulled off the suspected bad VCT unit, the cam is not damaged.
No visual external damage to the VCT and the 4 bolts holding the gear were tight.
The VCT appears to be a sealed unit, but I didn't have much time to look at it because the shop closed.
I will finish installing the known good VCT this afternoon.
As for the mechanics, 3 certified ones work at the auto hobby shop where I built the engine and do all the work. They agree with my diagnosis.
I'll try to gain access to the VCT internals. I may call in a favor and have the unit X-rayed.
Original VCT was malfunctioning. Known good VCT installed, bad noises stopped and engine runs smoother.
I will cut apart or x-ray the old one and post the pictures in the near future.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
