my GTT R34 gets about 400k - 650k depending on how much traffic caining I give it, this last tank went fast 460k, seems the fuel was lower quality or something, not more driving. soft power and a bit of fussiness on idle. even with NOS octane booster in it.
I'm pushing about 230-250kw and use all synthetic oils in everything and clean the injectors often and run octane boost (98 octane BP + NOS boost)monthly or more for runs
too much idling chews it up too.
just got new tires so see if that helps. bet its your AFM running rich,O2 sensor failing? clogged airfilter ?
have you checked your tire pressures it makes a huge difference on mine ?
and if I run with traction control off It must remap the computer for more power or something, blows thru fuel when its off? or maybe my driving style changes to a maniac..lol
has anyone dyno run on and off to see if it does?
  • Replies 40
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
