wow thats really bad i get 460 to a full tank and i drive normal and not so everynow and then and travel to muno and back all the time
i have a S2 with a 4" full system no cat or mid muffler and custom dump.
you should get that looked at
i used to use BP now i use mobil so what fuel you use
https://www.sau.com.au/forums/topic/242420-petrol-question-for-all-r33-owners/
  • Replies 41
How many Km's do you'se guys get out of a full tank of petrol?
I get about 320-350 when I drive my car sensibly and dont drive lead footed
My car is fairly stock tho, appart from a cooler and 3 inch turbo back
Is this average, or whats going on here?
well my fuel sensor is weird! at the bottom half of the tank i get around 100km and the top half around 200-250km
mine used to do the same till i lost economy i used to got 200+ kms before the gauge started moving now its around the 125 mark
all up i can push 400 out of it fuel light comes on @ about 300ish i used to not get the fuel light even little past 350
very inaccurate way of checking fuel consumption guys cause if the gauge isn't reading correctly, you could still have 100km's left in the tank when the light comes on.
Fill up & zero your counter, fill up again when your light comes on then make note of your odometer & litres used and divide one into the other.
The past 3 fuel tank in the last week or so I've been getting about 450km out of the tank, and that is with hard hills driving included + boosting hard with each fill up! and when I fill up I still have something about 6-9L left. Using BP Ultimate, about 180rwkw untuned.
I installed new coil packs just before i filled up the other night, and i reset the counter. I havent measured the amount of k's from a full tank for a few years now, and i've added a few mods to the car since i last measured it. i'll be interested to see if i can get over 350km's.
I think my stock ecu is making the engine run R&R - i get this massive creep of power after 5500rpm (the car literally throws me back in my seat); through the midrange its somewhat weaker. Not nice!
Need to do some investigating... The time for a powerfc and tune may be here...
Hey crew,
I get roughtly 11-12L/100kms, and have even been in the 10s. Fuel per tank is about 500-550kms.
This is with 11psi, FMIC, Full exhaust, and a fairly heavy right foot when in the mood - frequently :P
I might be one of the lucky ones with my ECU by the sounds of things. Come to think of it, even with higher boost, I have never felt flatspot, or R&R, that is commonally mentioned.
Guest
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
