Pod And Cooler
LTHL34
 Share
Hey Guys,
I have wanted a put a Pod filter on my car for a while now but i dont want to get an epa (because i have a cooler). Do you think it will be ok if i close off the pod with a airbox cover around it i will be ok????? I have attached a photo of the one that i want to get. How bad are the cops about this kind of stuff? anyone with experiance? thanks guys
cheers
michael
Hi Michael
I had the same setup when I had my skyline, cop pull me over and I asked him about my CAI box. He said it's fine. But I don't think its legal to have 2 induction mods.
I guess I was lucky. This topic have been cover many times before. I'm sure there is a thread under the mod section.
Cheers
Calvin
Hi Michael
Cheers
Calvin
Thanks mate, i just wanted to know if anyone has got away with it and how bad the cops are on this topic. i done a search but i could really find what i wanted.
Dont you have a high mount turbo and plenum???
nah mate i dont????????????????? i think you may have the wrong person.
thats just luck thats all
its illegal to have more than 1 intake mod
wether you have a pod cover or not, its still 2 intake mods
just depends wether you get done by the cop thats all
any officer/tmu officer that is experienced with our cars will spot that a mile away...best to keep it all stock i reckon..get a stock pod box and modify the bottom of the box by putting holes but not so that its obvious that its been hacked up.
A mate got his S15 defected and is putting back to standard for EPA. He got told by them that a pod in behind your front bumper is considered a sealed airbox!! Go figure. Also you can have an after market front mount if your car comes standard with one, I found this out when contemplating upgrading my Familia GTR one, was told because it comes standard with front mount I can put a bigger one on and it isn't considered a mod. Also told by the same Vic Roads guy that Pods are legal so long as they are dry and not the oiled type. No need to be sealed.
^^^ don't think it matters where u put the pod...if its a pod its a induction modification...if u had a cooler as well as a pod behind the bumper in its "sealed box" its still illegal.
same thing wether it has a factory front mount or not its still classified as another intake mod
so by law you cant do it, doesnt mean they will know though
Now ring vic roads twice more and ask the exact same question and you will get 2 different answers, if there willing to say that a bigger front mount is not classed as a modification get them to send you out a letter saying so because no cop is going to believe you, and even with the letter most cops will probably dick you anyway.
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
