haha~
ARC? which one is more expensive? lol, if u think the NRG are good, then we can group buy it~, but where? from ebay? lol
and can u make sure if NRG has 2 bolts or 3 bolts on the mount?
cheers
I'm in Melb.
The other brand i know is ARC. I read the people in US really swears that the NRG are good. but i don't know.
I just don't justify to spend a Sturt bar for nearly AU$500 unless we as Whiteline to make one for us.
  • Replies 54
keep in mind that the NRG bars have issues with touching the bonnet. there is very little room between the engine cover and bonnet
i got mine form STILLEN (www.stillen.com) their bar is by far the best from what i have read and my own experiences. all you need is the 350z engine cover instead of the stock one and it still looks stock :D
i got mine form STILLEN (www.stillen.com) their bar is by far the best from what i have read and my own experiences. all you need is the 350z engine cover instead of the stock one and it still looks stock :P
thanks for the info mate~
and pw350gt what do you think?! :)
plenum spacers are rubbish...
all they do is increase the volume of the intake manifold and thus lean out the mixtures across the rev range. that can be done more safely with an ECU tune
i have yet to see 1 pre and post dyno graphy showing a plenum spacer doing anything.
its snake oil until proven otherwise.
dyno proof?
same car, same day, no ECU tuning?
i'm happy to be shown clear evidence
http://www.350zmotoring.com/forums/modific...rawford-v5.html
I've been reading about this a fair bit as well and from what I can see, the guys in the US seem to swear by it and the gains are pretty noticeable.
ok my thoughts..
first, i can't access the dyno graphs as i'm not a member ofthat forum and thus can't downlaod attachments. but assuming they show a gain my though don't really change.
the good points in that thread:
- same car
- same day
- same dyno
the bad points:
- test was not independent (ie it was done by the manufacturer) thus an element of bias
- there was no comparison made against a stock plenum, only against an aftermarket (crawford) plenum
- and finally, the biggest issue, what were the AFRs?
you see, i believe all it does is lean out the air:fuel mixtures by increasing the intake plenum volume of air. if you can show me the air:fuel ratios i think the spacer will just show that the car has leaned out and this accounts for the entire of the power gain
to make my point, a good test would be put on the plenum spacer and check power vs AFRs. then, take it off and put the stock plenum on and tune the ECU to run the same AFRs as it had with the spacer.
so unless the graphs so something like AFRs etc on it, that thread is no proof that the spacer works
  • 6 months later...
i think we should do a group buy to register our interest, then go approach whiteline...hopefully, they should be around $150 as all they are is a piece of strengthened aluminium, 2 bolts, 2 hinges...
anyone here knows a contact at whiteline that can help? i dun wanna be the leader on this buy and would leave it up to a more capable forumnite...
Maybe, at the same time, whiteline can also do all the other various struts and braces for the V35....come on guys, let's band together!!!
I can see what you are saying BUT if you believe the gain is because of a greater volume of air making its way into the cylinders, would you also agree that with the same AFR, more air and the corresponding amount of more fuel results in a bigger boom, that is more hp?
After all, that's what a super/turbo charger set up does but to a much greater degree.
90% thats what an ECU does anyway. Give the correct AFR. Why bother o2 sensors if that's not the case. I'm also very confused by this "without an ECU retune" stuff. I've read it in every counter argument. In order to make any modification 100% beneficial (even running the car on 98 instead of 100octane really should be considered) you need a retune. What should be said is, same car, same dyno, with a retuned ECU without the plenum spacer and a retuned ecu with the spacer. A retuned ECU either way is bias but a test without a retuned ECU isn't going to show any 'true' gains.
A final point on ECU's; If what you say about allowing more air into and through the engine is true and the ECU cant keep up, the same can really be said for any airfilter, intake or exhaust upgrades. I know that contradicts my above statement but 100% 'efficient' upgrade or not we know that, within reason, a freer flowing intake and exhaust will show power gains.
Dont mean to sound like an antagonist just trying to understand what you mean.
/hijack
I know this is an odd (and somewhat nuebie) question but what is so special that makes the bars so expensive? I mean I have a factory bar from an SiR civic here and its pretty simple. It'd probably take me an hour to copy it. Same can be said for the brace on my SW20.
Please correct me but my understanding is that its meant to be a fairly rigid device to prevent body/chassis roll. If this is that case how much technology needs to go into it? Serious question; I'd rather have a friend tig up a chrome one than spend a small fortune on the same thing with a sticker on it.
Regards
nick
Regards
nick
Well if you can get one made for me (a CHROME one) that will fit the v35 with a SKUNK2 plemun spacer i'll pay up to $300. If it's good enough
i can / will organise a group buy for the NRG one if people are interested...
Does fit to a sedan~? :)
i need one. but i have a plemun spaer. So if there is one out there that would fit i'll buy it quick smart
If so, here is the list~
1. V35_Paul
2. Japav
I did a fair bit of reading last night on the topic. I'll start with a mild steal one and if that works then I'll have my friend tig up a chrome one.
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
    • Nissan needs to forget about building SUVs in every size possible and bring back the damn Silvia/200sx duo to compete with the 86/brz. Maybe with the Honda type r motor pointing the right way
    • Good to see you followed your heart, got your dream car and have it pretty well sorted out now. I think anyone can get caught out with a seller not being 100% honest about a cars problems. Can relate to all the electrical issues, had similar issues with my first car (mk2 escort) ages ago
    • I just bought the Nexus S3 for my gtt, haven’t installed it yet as I’m collecting parts to do everything at once…so far spent $14,000 The Nexus is nearly future proof
