  • 1 month later...
  • Replies 54
anyone interested?
>>>we are direct with stillen, but we highly recomend using the GT spec strut bar or the NRG strut bars instead.
>>>the GT spec will run you $225 shipped to AU.
>>>Stillen's bars have had fitment issues in the past so we've semi stayed clear of them.
>>>please let me know if you have any one else interested perhaps we can do a group buy and save on shipping >>>overall???
>>>[email protected]
>>>thank you!
>>>tony
Fox! you're good at it... GB!
anyone interested?
>>>[email protected]
>>>thank you!
>>>tony
HAHA edwin!!! thanks!!!
have you got ur kits yet? should b there 2day or tmr.
i've got my strut bar already, it's the Circuit one piece bar,
http://www.frsport.com/Circuit-Sport-Tripl...G35_p_2571.html
it is pretty ok as i've been using it for half year already, but to tell u the truth, it's just for look! haha
if u want something to improve ur handling, get sway bars.
may b tomrow, I'll be installing them friday wit spacer which arrived monday!
does ur brace clears aircon piping stock eng. cover and 5/16 spacer?
well! if there's no handling improvement probly think twice b4 getting one.
tnx!!!
Sorry for the slightly off-topic post - but how long ago did you recieve that reply from Tony @ riverside infiniti?
I placed an order with them for something over a month ago, still not arrived and they've been ignoring me.. paypal dispute in progress but no response to that either.
do what i did - make an international call.
got that reply tuesday,
and my spacer... paid it monday and received it after 5 days!
here's another reply for GB:
>>>the GT spec bar will be $1070 for QTY 5 shipped out to you overseas.
>>>this is roughly $214 each bar AFTER shipping...
>>>please let me know you can email me directly at [email protected] as well.
>>>thank you
but I'm not sure if I'll go ahead with the strut bar... like what fox said! "no improvement on handling"
if you take your car to the track there is an improvement on handling, due to the reduced chassis flex etc. when putting the extreme stresses on your car from fast cornering.
the stiffer the chassis, the better the car will be around the corners. and with a heavy car like the v35, all things will help.
sway bars make much more of a NOTICEABLE difference.
(ps if anyone in sydney need help installing their motordyne iso thermal spacer, i can do it for you - pm me)
b.t.w guys there's two separate forum threads for Strut bars & Sway bars on G35 Driver that compares models from different manufacturers. Some strut bars will foul your bonnet whilst others may not give access to damper adjustable coilovers, worth doing some research.
Just paid for my NRG strut bar. 6 to 10 working days and i'll have it. i'll keep you guys posted with any noticeable difference.
I'm looking for support when i drive up and down "crazy" kerbs in Geraldton WA. I can hear my bodykit squeak when i pull in and out of driveways.
v35 paul
do you have a plenum spacer?
let me know how you go with the installation
looking at Fox's Strut bar tonight, it will not fit with the stock engine cover + spacer
might fit just with the spacer
-mark
hey mark,
i've checked , actuelly it will fit 5/16 and 1/2 spacers.
but won't fit stock engine cover
  • 3 weeks later...
v35 paul
-mark
Put it on on the weekend. it fits :(
if you had spacer and cover on it would not fit. But just the spacer is fine. It's only mm's between plemun and hood of the car.
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
