Item:6 x 480cc Injectors (JDM S15 Turbo Manual Injectors)
Age: Sourced form late model JDM S15's
Condition: Very good
Price: $700ono..But willing to negotiate price. Will post at buyers expence ($10 postage)
Contact: VIA PM
Comments:These Injectors are a direct replacement to your stock 380cc factory Injectors. I bought 12 JDM S15 injectors for My r33... Only need 6.. So selling the other 6. Enough Flow for around 300kw. Got no Pic's of em yet.. But will end em up soon.
Edited by Dush
  • Like 1
https://www.sau.com.au/forums/topic/242494-480cc-injectors-for-rb25det/
im intrested and would buy them depending if the top feed or side feed and if the price was NEG
They are a direct replacement to replace our stock OEM Injectors... they are Side feed
PM Sent
Guy I need these Injectors Gone asap - If your having any doubt about em Ask your Mechanic or do a search on the Forums about em... Its open to any offers...
When injectors are cleaned/tested & flowed. They replace the O rings and the fuel filter in the injector. also cleaning out the Nozzle's were the fuel is ejected form.
They come up pretty much brand new...
Edited by Dush
This is actually good price for something that are really annoying to get (believe me I've searched!), and japan brand injectors are getting expensive now (current exchange rates).
Pity I'm not going ahead on my project or I wouldv'e bought it off you to save time!
Wish you all the best with the sale Dush.
Cheers
Grant
It's hard to get 6 together... if you want 4 then find someone with 4 as that's what most people will have... Then perhaps someone like me when time comes around can get 6 together:p
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
