  • Replies 64
Whats a safe boost limit to run on an R34 GT-R V-Spec II? I only have Blitz Nur cat back exhaust & the rest is completely stock. It seems that most people say that 1.2 BAR is too much even for R34 GT-R's stock ceramic turbos? Is this true? Has anyone actually shattered their stock R34 GT-R turbos from 1.2 BAR boost?
I am contemplating getting the Greddy Profec B-Spec II and bumping boost up to a max 1.2 BAR... but then again maybe not?
Thanks in advance for any info/help!
it'll work, but it will eventually go bang.
The general rule of thumb for ceramic wheeled turbos is no more than 1 bar.
I ran 17-18psi through a toyota ct20b turbo (ceramic) and it lasted a bit over a year before it spat out the "fins" on the wheel :P
doesnt the R34 run steel wheels from the factory?
if they arent ceramic, and they will hold together at this pressure, ur still talking about wringing dam near 18psi out of tiny stock turbs, not sure how efficient they are at this boost...could be fine...but worth finding out
also just adding more boost without a retune wont yield the best results, look for some aftermarket management, even a piggyback ecu is a good option if you only want mild mods
uve spent money on a nice car, dont risk doing damage by increasing power/boost without making the appropriate support mods
Okay I see. So aftermarket turbos will be a necessity!!! But having said that, then the support systems will have to match... so what about the following then:
HKS GT-SS Turbos
NISMO 600cc Injectors
NISMO fuel pump
Apexi Power FC & Hand Controller
Trust Oil Cooler
Then Trust Profec B Spec II boost controller running @ 1.2 BAR.
Should produce some decent power/reliability then eh??? Or am I missing somthing here? :P
R34 GT-R's still run ceramic wheels. Its only the R34 N1 that have steel ones so unfortunately i dun have them. :P
u dont need dumps, just get front pipe and a boost controller. I run 1.2 bar for daily driving, no dramas at all as you are not on boost all the time.
If I do a cruise, putty road for example where it will be on and off boost constantly I just knock it back to 1 bar.
Ive got mine set to 1bar as those internal gates arent very good at controlling boost in the first couple of gears which can spike boost to 1.20
test your boost in 3rd on the freeway all the way till bout 7000rpm and check the highest reading; it should be 1.01 or 1.04 etc
you want some leeway to keep the spike down; if you set yours to 1.20bar im sure it'll go higher when you take off hard in 1st and full throttle 2nd.
Then they will blow!
add dumps and front pipe and you've got a winner :ermm:
Have you seen R34 GTR Dumps?
They dont need changing at all, they are easily good for over 350rwkw.
See Snowman's graph, thats with stock dumps and better than most people on here for the power.
Stock airbox
Stock dumps
Dont need a EBC really
  • 2 months later...
I'd like to see where people are getting their information on R34GTR's having ceramic turbine wheels. I have information to the contrary by a reputable Garrett company and tomorrow I will have proof when I check the one I have here. Stay tuned.
Maybe the people that have killed them?
GTRGeoff purchased Snowmans old turbos (ceramic), they spat a rear wheel just like any other GTR turbo does... i think cost him a motor possibly too, again, just like ant other GTR turbo can do
Ive turned my boost down a tad, ramps to 1.05 or so in the first 2 gears, 3rd gear full load is 1.00kg/cm on da dot.
umm something in r34 gtr turbos are ceramic, nissan did it to increase torque over the r32/33; mine are holding up nicely still but i will be changing to some new garrett or hks items simply for reliability.
so R34 GTR has better dump pipes than R32 and R33 GTR ??
my car is stock at the moment apart from Fujitsubo Legalis exhaust , K&N panel filter and 100mm thick intercooler
during the day boost peaks at 1.1bar and at night 1.25bar
and i dont have a boost controller .... :happy:
what should i do ??
Edited by TuLaLiT
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
    • Hey guys I’m chasing a Rb20det complete or bare block need a good running engine as mine has low comp
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
