Does anyone know the lift and duration of the DE cams? I'm currently looking at upgrading my cams but was thinking of going RB26 cams.
The RB20DE has ???deg - ???mm lift intake & ???deg - ???mm lift exhaust
The RB20DET has 240deg - 7.8mm lift intake & 240deg - 7.8mm lift exhaust
The RB26DETT has 240deg - 8.5mm lift intake & 236deg - 8.2mm lift exhaust
https://www.sau.com.au/forums/topic/242509-na-cams/#findComment-4237990
RB20DET
Ex - 240 duration, 7.8 lift, opens 60 BBDC, closes TDC, LCA 120
In - 240 duration, 7.8 lift, opens 5 BTDC, closes 55 ABDC, LCA 115
overlap = 5, LSA = 117.5
RB20DE
Ex - 240 duration, 7.8 lift, opens 57 BBDC, closes 3ATDC, LCA 117
In - 232 duration, 7.3 lift, opens 5 BTDC, closes 47 ABDC, LCA 111
overlap = 8, LSA = 114
Now, if anyone understands all that ...
It would appear the best might be to just use the DE Ex cam.
https://www.sau.com.au/forums/topic/242509-na-cams/#findComment-4239495
bit off topic, but blind elk, where did u get those specs from?
ive been looking for a good source for skyline cam specs and the best ive found is the tomei chart, ur specs are far more detailed
They are based on the Tomei specs. Just need to understand what each bit means then you can calculate the other bits.
(R32) RB25DE
Ex - 232 duration, 7.3 lift, opens 54 BBDC, closes 2 BTDC, LCA 118
In - 240 duration, 7.8 lift, opens 9 BTDC, closes 51 ABDC, LCA 111
overlap = 7, LSA = 114.5
https://www.sau.com.au/forums/topic/242509-na-cams/#findComment-4240164
  • 5 months later...
from the info that i have gathered from fellow mechanics, the diff btwn the silver top DET n DE are the difference in lift.
the DE ones lift higher than the DET ones.
The red top cams have slightly more duration than the silver top one's.
anybody can confirm this??
https://www.sau.com.au/forums/topic/242509-na-cams/#findComment-4548372
duration = how long it keeps the valve open for
lift = how much it opens the valve
opens 5 BTDC= 5 degrees before top dead center
closes 55 ABDC = closes 55 degrees after bottom dead center
LCA = lobe center angle?
overlap = how many degrees both intake and exhuast valves will be open at the same time
LSA = lobe seperation angle
https://www.sau.com.au/forums/topic/242509-na-cams/#findComment-4548487
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
