  • Replies 40
whats that going in?
went all out and got the v88 :laugh:
Yeah...its going to give me all the features i need...the cooking model Apexi Power FC was holding the car back from performing to its optimum. Flat shift, anti-lag, logging etc...is needed to go to the next level...free revving the car off the line with zero boost is now a thing of the past. Its going to be a handfull!
It doesnt look as pretty as a motec :laugh:
Whats the little green circuit board i spy just above the ECU itself?
plug in adapter?
yes its a nissan pin-out plug....will save me a lot of time on installation.
this ecu combined with the 1100hp turbo upgrade, fully optioned PPG straight cut dogbox and a slightly lighter car should give me the hardware to chase the ANDRA class record...ive just got to get the skills (balls) to drive it to its potential.
Edited by DiRTgarage
looks sweet.
reckon the launch control etc will go better?
what power / time you expecting now?
why go this one? value for money or you know the distributer or features or what? a car of your calibre would have had a few options im guessing?
boost off the line is needed to get the 60's into the 1.3's (my best is 1.41) to run the low9's-high 8's
should be good for 900+hp at the tyres and with 3000lb's should be a high 8's car (without NOS)
i went with this one as its the best on the market $ for performance than any ECU, it performs as good as a MoTeC M800 without the huge pricetag. Its features, processor speed etc is equal to MoTeC and Ray Hall's after sales service and technical back-up is second to none...it was a no-brainer really. Mark Jacobsen doing the tuning is another bonus for me...in my opinion he is one of the worlds best GTR tuners.
if i can run this with success then it will give others confidence that they can run one too. I help market this product because i believe in it not because i make money from it. I have always given free advice on here with products ive found to be good and bad...if its not up to the task, ill definately say so. Stay tuned :laugh:
Awsome, grats on your new goodies!
i heard they cant be used for r34s? is this true?
( i must have looked at a old mag issue)
all the Vi-PEC ecu's (V44 plug-in, V44 wire in and V88 wire in) can be used in an R34...except with an auto model you must retain the factory ecu to run the auto and use a wire in V44 or V88 to control the engine
Looks a lot like LINK ecu from outside. + the packaging is similar.
looks can be decieving
Can you guys get it through your head this is not a rebranded Link g3 or other ecu...
Alright i have read on there that the vipec is just a re branded link/adptronic(SP?)
i got this from the evo site by ray hall himself
"Hello Everyone,
When I stopped selling, promoting and supporting the Autronic product, I went looking for a replacement, as many of my old Autronic dealers wanted to stay with what ever I was selling. After some months of negotiations with a few company's I settled on one of them. They agreed to build me "new" ECU under by own brand name. They also were willing to build them to my specifications. After many years with Autronic I knew exactly what I required based on years of requests from customers. As many of my Vipec dealers had only worked with Autronic ECU in the past, it was important that the ECU used the same fuel control stragtery software, had QuickTune (Autotune) and used many of the same keystrokes.
The Vipec is not a rebadged Autronic or LinkPlus G3. It is a totally new range of ECU. We plan to make a range of plugin ECU for the EVO1 to 8 and the EVO9. The plugin for the EVO4 to 8 will be available next week. This is based on the V44, with extra injector and auxiliary outputs, plus more analog and digital inputs. It is what some have called a V64."
A friend of mine here in Newcastle who owns Mastertune Engineering (Lincoln Russell) has done a lot of the development of this product and i know how much work has gone into it to get it up to the performance level its now at....it may share some components of the Link but that is all. He was also involved in the development of the Autronic SM4 and rates this product far superior than it...the SM4 is an awesome product so thats a big call for him to make...but he has voted with his feet and upgraded the ECU in his VL 4WD RB26DETT...yes a VL with all GTR running gear to a V88.
I have heard it a few times, but i won't belive that Lincoln would say anything is better then Autronic unless i heard it from his mouth, and I did.
Made me feel that i should give back this SM4 and get one too :ermm:
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
