Hey guys, i have R33 gtst 95 model, rb25det engine, anyway car is basicly stock turbo, stock computer, has 3" turbo back exhuast, greddy fmic, avcr b/c, split fire coilpacks, walbro 255L fuel pump installed, now if im travelling along at 60km/h drop it back to 3rd or 2nd and flatten it, goes through the rev range fine until it gets to 5000rpm then it feels like it drops off power until about 6000 rpm then comes on full power again until redline at 7200rpm, now i dont know much about the avcr i have it set up on self learn mode, i have been told that its not the best way to run it, but i just got it set up so it goes to all stars and left it so it was safe, running 10psi which is about right with what a standard car would run with ungraded exhaust on it. still does has this problem at that boost. any ideas??
Cheers
Daz
my car does this aswell
but mine is a r34 gtt auto and doesnt have the mods you do, pretty much stock.
revs up smoothly till it gets to about 5k
although depends what gear its in. 1st and 2nd gear revs all the way smoothly. this happens in 3rd and 4th
also curious to find out what causes this...
plugs are gapped down to 0.8mm, unless they have opened up in the last 3000km since i changed them at my last service, and also
The R+R thing seems to be what its doing, but on the avcr it wont drop boost below 10psi coz that's what it runs standard now with the exhaust and extra flow. i have got it running pretty much the lowest boost it will with the standard wastegate.
Either get a safc II as a cheap fix so you can trick the AFM readings so it won't drop in to R&R, or go the half hog and get a piggy back ECU or go the full hog and get a replacement ECU and get it tuned.
Getting it tuned will change the way you car feels. It's worth the dosh
I have a power fc sitting here ready to go in, but was going to wait till i got bigger turbo and injectors first. so dont wanna get it tuned yet. the thing is it never really did this before i had fmic and avcr and fuel pump installed, so its gotta be one of these things that are causing it to do that.
Yes, well a tune will fix your problem though. Your standard ECU is having trouble trying to manage all these new changes you've added to the car, its freaking out and trying to play it safe at the expense of your fuel and performance.
i have the same problem on my r34 neo gtt b4 but mine is totally stock in the hood but same with you its cutting from 5k -6k then goes smooth from there. my problem was the spacings on my plugs, when me and tony took it out and put new 1's in with the .8 spacings problems went away.
thanx for that. i will be replacing the plugs again soon. so il post in here if its fixes the problem. i actually have coppers in there at the moment and gapped them down to 0.8 , they have only been in for 3000KM but i will put the iridiums back in maybe this weekend, see if its changes it at all. the gaps on the coppers might have opened up in that 3000KM and could be causing the problems.
noob question but how do you "gap" them?
well, when u buy plugs they come with a different gap sizings between where the tip of the plug is where it arks to, you have to get some feeler gauges, which come in different size gaps you put them in between where the tip is and where it arks out on the plug and tap the plug gently against a bench or something so that the gap will decrese in size to the size of the gauge. that makes it easier for the spark to travel across the distance bcoz its not as far for the spark to travel. normal copper plugs u buy are usually about 1.1mm gap, the iridiums are already gapped down to a 0.8mm so you shouldnt need to touch them.
Well you can buy them pre gapped. Iridiums do come as a 1.1mm. So if you want .8's you buy .8's, if you want 1.1's you buy 1.1's.
yeah u are right i think. lol but i really have never bought 1.1 for my car in iridiums, not really worth it in turbo cars.
yeah I bought 1.1's for mine and haven't experienced a problem with them. But for everybody else, may as well just cut the crap and go for .8's. Spark plug gap arguments are another topic by itself so I won't raise it in here :P
Well today i got to and managed to change the plugs back to my iridiums from the coppers i had in there gapped down to 0.8, and now that the iridiums have been sandblasted and cleaned by me at work, there like new again, and work great. rev's all the way through the rev range now without hesitation, cheers guys, i had a feeling it might have somehting to do with the copper plugs. but seriously they were only in for 3000km and the gaps must have increased or something, i thought they woudl have atleast lasted the 5000km but turns out they didnt, but they plugs werent that dirty either.
I had the exact same problem in my 33. The car feels like it bogs down in that rpm range (feels like going through wet sand or something), so i purcahsed power fc, got it tuned and it now runs great, pulls hard all the way to redline!!! Your pretty lucky that it was plugs, it wouldve saved me a lot of money if it was the problem with mine!!
Edited by RB JET
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
