Ok, so im stealing this idea from the r31 club, an idea which has been successful a few years running. They basically do a Calendar each year with members cars from around Australia, and cost bout $15-$20 per calendar.
So throwing the idea to you guys here, I would be keen to do something like this for SAU members - SA only though. Im gonna suss out a few places tommorow for printing, but if theres enough interest from people here, I will get you to submit photos and I will go from there.. It will cost probly no more than $20 per calendar im pretty sure, which is about what any other calendars sell for in retail shops anyway, but with our SA cars in it.
What yas think?
Edited by *flick*
  • Replies 486
Posted Images
Yeah, pics alread taken, or what ever people want to submit to me. Once i got more details, Ill get people to start emailing me photos they would like to submit, and Once I have a fair few, Ill take them to the printer and come up with a design.
Once its in production / when I have a price, Ill get people to put a deposit, or pay in full even to order their copy.
Stay tuned! :laugh:
u should put up say 24 pics and get ppl to vote the 12 with the most votes could be put on the calender that way theres no bitching that someones car isnt on there and its the peoples choice
just my 2cents
yeah keep that crap drty2 1 off there, i wouldnt wipe my rear end with pic of that thing.
ive got pics of mine on air race track :laugh: also charmainy has some funky pics
charmaine, I might take you up on the offer of using some of your pics. Would be cool to have maybe a few group shots, like from cruises etc aswell. But ALL photos will be considered that everyone has taken, want to make it fair and have a wide variety of shots.
Kye, good idea but ive got a few ideas on the go, will run it by everyone after ive spoken to a few printing places.
Submit all photos to my email [email protected]
Try make them fairly hgh res if possible and decent size, will be easier to work with, but send me what ever you want, and how ever many you want - of individual shots, group/cruise shots etc.
I will try include as many as I can.. my main idea at the moment is that each month will feature a single car as the main pic, with smaller pics of others down the bottom (thats how the 31 club did it), and maybe one month of a big collage of cars.
But yeh, will run the drafts past you before printing :laugh:
Edited by *flick*
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
