  • Replies 486
Posted Images
hey flic very keen on a sau calender.
have a pic here.. if one is needed with better background and better camera would be more than happy to get one to you asap
Jenkies, can you email me a photo rather than attatching it here? Uploading it to here downsizes it a bit, high res is better.. I wont be using photos downloaded to the forum
Going to the printers tommorow.. Luke and I are sitting down tonite to go through all the photos and pick out what to take.. so get in by tonite if you want to be considered!
So at this stage, the deadline is tonite.. but that could be extended, depending on what the printers say tommorow. Will let you all know!
just a few photos sent to flick, hope your mailbox isnt flooded...lol
if you need help editing Im around tomorrow. i ran out of time editing this week , hope you found something useful. need to go on more cruuses to get more photos..?
ok guys! Been and seen the printers. All main photos are picked out, the ones that look best enlarged.. everyone that sent me a photo will more than likely be included, even if its just a small one. Some that were sent from a mobile phone camera, are hard to duplicate and print.. but will see what they can do.
The calender will be A4 size. 1 big pic and as ive said many a time, smaller ones below the dates.. Saw a sample and gonna look pretty good I think.
They are doing up a draft and im waiting on a final quote and I go back next thursday.. so I have until then to design the front cover!
haha nah you cant know yet whos photos made it to the main pages :) Thats a secret :banana:
The quote may take a few days to come through, im surprised and quiet happy though, as the setup fee rough quote was alot less than I expected! And alot less than some other places told me. Will know by early next week I reckon, what the price on each calendar will be.
Lee the calendars will be no more than $30, bout the average price of a calendar you would get from any other shop. Im thinking they will be more around the $20-$25 mark, going from what theyve told me both times ive been in there.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
