  • Replies 486
Posted Images
dont forget my PC luke
you mean my pc? XD
not sure what i want to do with it yet, one of my friends said they wanted it a while ago =\ and it's also on offer to ben and nene if their computer dies on them coz they have helped me out a bit... so i think i'll be hanging on to it for a little longer, soz
what there's Nothing wrong with Nene's computer might need another gb of ram but thats it
it was crashing all the time =\ mebe they bought a new one... but the old one seemed pritty broken from what nene was saying
thats all cool mate
the only reason i was after it is my CPU cooked itself
overclocked the motherf**ker
3.2GHz overclocked to 3.6GHz
it ran fine for just over 1.5 years
thats all cool mate
what sort of cpu/socket? I have a couple cpus lying around
-D
3.2 intel would either be the (640) or possibly older my guess is 775pin 640
Luke its a 1yr old HP Pentium D 2.8 ghz i think and i think it has like 512mb of ram but it may have 1 1gb stick really cant remember possibly just needs a format
3.2-3.6 isnt much of a OC i had the P4 650 stock is 3.4 running on 4.02ghz on air
But also dont forget over clocking a little bit 3.2 to 3.6 and have a shitload of services run on your pc at the same time is not a good mix
plus it has lasted well just over 1.5 years so thats a good deal i reackon
and that computer was rarely shutdown as it was acting as my server
it was also my test DEV pc for random things like studying for exams or just trying to get something to work
Well luke if you still wanna do this then the offer is there for you my friend
If you can double check which socket it is, I'm sure I can find you a replacement. I have at least 2 intel chips and 2 AMD 64 chips so I just gotta pull them out n see what they are...
-D
Good news guys! Got the call that the calendars are ready to be picked up thursday! Sooo next step is getting them to you guys.
Im happy to meet people on friday at vilis, just not sure what time yet, otherwise can work something else out.
At this stage theres still 5 left for sale.. I thought they would be snapped up alot quicker than this, but all good.
Those that put their car in but havent paid yet, let me know what you want to do, as to order more i have to do lots of 5, paid upfront.
*edit*
Im paying the difference for this first lot that is going to be collected so I can get them out asap to you and cos im so excited bout them, but the next lots of 5 I will need paid in full, so 5 payments.. before I will collect them
Edited by *flick*
awesome Ben :ermm:
I had u listed in my book as reserved lol so your safe there :(
And Preiss aswell has 1 reserved.. so thats 22 sold, 3 left!
Im happy to sacrifice the one i was gonna take, and buy up in the next lot. To get the 5 extras printed, would only take a few days the printer said aswell, so if you miss out on first round dont stress, its easy to get more!
Edited by *flick*
I get paid tomorrow, put me down for 2 flickster.
-D
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
