sorry for post whoring but who owns the major old school skyline thing? the prince or car formaly known as prince?
someone should know what im talking about, get a pic of that 1 in there :( i think he's still in the middle of fixing it up though ;)
The prince + The DR30 would be great to have on there... classics deserve props
-D
  • Replies 486
Posted Images
Are there enough good cars of each generation to make it flow from the Prince Skyline GT-B right through to R35?
I'd say so... the R35, well you'd have to ask Willall for permission for pics... No problems for r31-r34's, the prince and the dr30 are both in really good condition, so it'd be a case of finding r30 and the other earlier models. which is going to be the hard bit i'd guess
-D
Matty can help us out with a photo of the prince, good mate of his owns it. 'Benny Blanco' on here has a DR30, which i would love to include, i think i have some of his anyway from a photo-cruise i organized last year.
Cheers for everyone thats submitted photos so far!
Ben, Nene, Send me some of yours! and of the GRIM aswell please :(
ill be keen for a calender, also i know its a skyline sight but would u consider a nice jzx100 chaser as a car for the calender, if not, i have very good picks of my old skyline if u want to but them on it, thanks
Can't speak for flick or public opinion, but I'd say the skylines are the main aim. A separate stag and separate other import calendar are always possible..
theres only so many photos u can have on a 12 month calendar, sadly
-D
Edited by Dohmar
would rather just not have anything
to do with the sad-act.
please let it all go and turn this thread back into chat about the calendars
shakes head, and after i came over to your house when you were new on the forums and taught you how to install dash cluster globes, ah well
someone should know what im talking about, get a pic of that 1 in there :( i think he's still in the middle of fixing it up though :)
yes Dan your thinking of Pete with the 66GT av-17334.gif<<<
^^ think that shit needs to go to pm, no one wants to read about it from either of you.
I had an idea for the cover, having the SAU logo on top with Skylines Australia under it, and then under that a sequence of taillights in the dark, so going from 31 through to 34 or even 35 maybe if we can get a pic like that. But yeah not sure if i making it easy to visualise but hopefully you get the idea.
Here's a pic I'd love to include but I want to go back and re-do it, this time with my heslo plates and standard GTR front bar, if you want to include it let me know and I'll go back and take another :(
I'd like to see some maturity displayed from here on in in this thread, therefore the hostility will cease now guys. Simple as that. The kind of comments that I have had to removed have no place on this forum.
Continue back on topic...
Good idea by the way. I'd be interested in offering my car for photograhic purposes, or at the very least owning the finished product.
i have a few pics that wouldnt mind showing but i cant upload for some reason. Could u please P.M me ur email address Flick so i can send thru or can see them on http://s284.photobucket.com/albums/ll6/scott_1982_r32/
If u want any, and they're good enough just ask and i can send thru a full res copy
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
