a3 thats pretty big, does that mean its just a single sheet? as in you dont flip over for each month.
Nope, still a 2 page per month (1 page pic, 1 page date). They have a template for both that and A4, so going to see which works best
What about mine flick? Im going tomorrow night most likely to get the updated shots, still keen?
Hell yeh still Keen! Like I said in the email, that shot is awesome, so with the new bar and plates, is a perfect shot :yes:
with the difficult choices and arguments soon to follow its a good thing absolutely everyone agrees my car is the best in the club and therefore should be in the star position in every spot :) no room for opinions on this beast. my car fires up in the morning and pisses excellance out the exhaust
Lol! Think I need a second calendar just featuring your car :P
Got your emails, thanks :)
  • Replies 486
Posted Images
Hey you know how some calendars have them empty squares - example:
Them last few days highlighted in blue - can put SAU SA member's cars in there instead yeah?
P.S. just sent another e-mail with a couple photos before and another one in a second :)
similar idea to what we have vu, there wll most likely be photos running along bottom, but will probly figure out in the setup process where is better, in the blank spots or under the calendar part itself.
Anyone else have any ideas for the cover? If not i may need to borrow a 32,33 and 34 for their tailights one night :)
Vu, Like Luke said thats very close to the plan - the photos will be underneath the last row of days/dates.
ALtho, it all depends on setup cost and how much it will make each calendar cost.
Thats the next the next thing I need to know, how many to order.. Once its setup, ill need numbers for how many to order.. I will need people (after friday when I know the cost) to let me know if they want one - REGARDLESS of if their car may be in it or not. I Wont be able to show you guys a draft of it, as that stays with the printers, so I need people to be understanding and patient, but also let me know if they want one. Alot of people ahve already said they would take one regardless.
So after friday, ill be making a list of all the people wanting one, so if u can let me and ill add u to the list..
Thanks,
Flick
put me down for 1 ,
photos coming thursday afternoon flick, hope your mailbox can handle large files, and your pc as well...lol
dont forget RGB photos will shift colours in CMYK 4 colour press printers and wont look the same ?
who are the designers if you dont mind me asking? pm ?
Matty can help us out with a photo of the prince, good mate of his owns it. 'Benny Blanco' on here has a DR30, which i would love to include, i think i have some of his anyway from a photo-cruise i organized last year.
Cheers for everyone thats submitted photos so far!
Ben, Nene, Send me some of yours! and of the GRIM aswell please :)
Sorry just read through the thread... I have no probs with you using my car.... dont have any new pics though just the ones you took...
You can put me down for a copy either way..
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
