  • Replies 486
Posted Images
hey flic very keen on a sau calender.
have a pic here.. if one is needed with better background and better camera would be more than happy to get one to you asap
Jenkies, can you email me a photo rather than attatching it here? Uploading it to here downsizes it a bit, high res is better.. I wont be using photos downloaded to the forum
Going to the printers tommorow.. Luke and I are sitting down tonite to go through all the photos and pick out what to take.. so get in by tonite if you want to be considered!
So at this stage, the deadline is tonite.. but that could be extended, depending on what the printers say tommorow. Will let you all know!
just a few photos sent to flick, hope your mailbox isnt flooded...lol
if you need help editing Im around tomorrow. i ran out of time editing this week , hope you found something useful. need to go on more cruuses to get more photos..?
ok guys! Been and seen the printers. All main photos are picked out, the ones that look best enlarged.. everyone that sent me a photo will more than likely be included, even if its just a small one. Some that were sent from a mobile phone camera, are hard to duplicate and print.. but will see what they can do.
The calender will be A4 size. 1 big pic and as ive said many a time, smaller ones below the dates.. Saw a sample and gonna look pretty good I think.
They are doing up a draft and im waiting on a final quote and I go back next thursday.. so I have until then to design the front cover!
haha nah you cant know yet whos photos made it to the main pages :) Thats a secret :banana:
The quote may take a few days to come through, im surprised and quiet happy though, as the setup fee rough quote was alot less than I expected! And alot less than some other places told me. Will know by early next week I reckon, what the price on each calendar will be.
Lee the calendars will be no more than $30, bout the average price of a calendar you would get from any other shop. Im thinking they will be more around the $20-$25 mark, going from what theyve told me both times ive been in there.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
