dont mind me asking, what sort of remap r u doing? and where aT? and how much KWs u rekon ul be getin? cos i wana get mine rre-done to? thanks
i fink ill be doin a stock ecu remap from dr drift, and mods i have are fmic, air intake, turbo bak exhust heavy duty clutch, boost controller. so im hoping for around 200kwaw
