All parts are from a 2 Door R32 RB20DET
Make an offer on these parts as I am unsure how to price them.
Good Condition - Rear Lower Quarter Trims (LH & RH) with no cloth trim (perfect for speaker install)
LH & RH A-Pillar Trims - VGC and Not attacked from gauges.
VGC Side Step Trims
Average Condition Centre Console with torn handbrake boot
VGC Steering collumn plastics
Factory RB20 AIRBOX! (afm bolts up to this)
RB20 AFM
VGC Glovebox & Side Glovebox Trim
STD ECU from the Auto Version (Its plug and play I beleive with manuals, just runs slightly more ign timing)
Viscous Hub & Fan
Rad Fan Shroud
Alternator
Power Steering Pump
Air Con Compressor
Climate Control Computer
Front and rear seatbelts & stalks
Bare dash no vents - slight bubble above glovebox but vgc apart from that.
Ign Barrel & Tail
Indicator Combination Switch
Turbo aluminium outlet pipe
Factory cast dump pipe with o2 sensor
Rubber turbo Inlet pipe for turbo with metal lines from breather and BOV
Small Door Pockets LH & RH
Nismo Type S Suspension (std height but adjustable dampening and handle very well and are comfortable)
Rear twinpot Calipers
Rear diff centre
Rear windscreen
GTR Rear wing
Factory steering wheel (average condition)
Interested. What condition are they in? Any idea on age?
Could I get some pics?
Sorry guys I thought my location was in my thread..
im located In Perth...
Suspension looks like it has done 30-40 thousand kms
I also have for sale the little black box that sits on the firewall which reads boost for the guage in the cluster.
Im after some RB20 parts,
Would you have
* turbo coolant line that goes around the head.
*ECU temp sender, big yellow one
*turbo to mani nuts
  • 4 weeks later...
hi, just wanted a price on climate control unit. and if possible, postage to postcode 2770. also,what kind of condition is it in? if you can let me know, id b greatly appreciated. thanks, luke.
  • 3 months later...
hey dude dont happen to have computer? or trim bits that go around rear quater windows?or bits that cover the join from carpet to seat panel?cheers 0431 540 141
