HI All ,
my car is a r34 GTT
hopefully you guys will be able to provide some insight to this issue for me.
ok i went to the shops before car started fine with no issues drove fine no issues.
but when i came back from getting some milk unlocked my car , turned the key nothing at all could hear the fuel , no starter motor nosie , no clicks , ticks motor not turning over?
all electronics are working battery is only a week and abit old , i also tried to jump starting it , no luck :)
thought possible my immobilizer was not disengaging , but i was able to push start it with no issues.
able to drive home car was running good. i went to try to start it again after i got home , NO LUCK same thing again turn the key nothing but the electronics and fuel ?
any help or ideas would be great
thank you kurtis
https://www.sau.com.au/forums/topic/242578-starting-issues-r34-gtt/
A common problem amongst old car's is that the starter motor doesnt work when engine is hot.
"he heat generated in the starter by the engine and the exhaust pipes (sometimes) causes the armature to expand. If the bearings are worn then the armature drags (actually contacts) on the stator causing a short circuit and a high friction drag. Sometimes just replacing the bearings can fix the problem. "
Although your car is quite new, im having doubts that it could be the starter motor?
See if the problem only occurs once the engine is hot? Best to take down to an auto electrician and ask for a free alternator/starter motor/battery check-up. :ninja:
  • 10 years later...
On 10/30/2008 at 11:22 PM, KURTIS34 said:
HI All ,
my car is a r34 GTT
thank you kurtis
Was this ever resolved? I am having the exact same issue in my r34 gt right now.. I drove it perfect this morning to the shops. Got back in and nothing when I turned the key.
Try to start it with a 50c piece direct onto the solenoid terminal from the main cable (at the starter motor itself).  If it will crank there, then you have a problem with wiring between there and the ignition switch.  If it won't, give it a whack with a soft face hammer or a lump of wood and see if it will crank after that.  If it will, then the solenoid is sticky, which probably means full of clutch dust, but it could just be warm.  Finally, they can get grumpy when hot, when they get old.  If it works when it cools down, then there's your answer.
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
    • Nah. H2S. H2S is "rotten egg gas", which is what is associated with no cat. SO2 is equally nasty, and if you've ever smelt it you'll know all about it. More of a choking, acid in the back of the throat sort of thing. But you can only smell it in a narrow range up to about 1ppm. Above that, it irritates your mucous membranes, but you don't smell it.
