Just Jap Racing is pleased to announce the latest addition to our growing Carbon Fibre Parts range, the long awaited JJR Carbon Fibre Cold Airbox for Nissan Skyline GTS-T & GTT
The JJR Carbon Fibre Cold Airbox is a high quality and super lightweight, 1 Piece Airbox setup, designed to shield aftermarket Pod type Air Filters against engine bay heat from the Turbo side of the engine, helping to improve performance while at the same time enhancing your engine bays appearance.
Each JJR Carbon Airbox features a high quality durable gloss finish, and is compatible with most popular Pod Filters including M's, Apexi Power Intake and HKS Super Flow.
Designed for vehicles using standard Air Flow Meter.
In stock and available now for the following vehicles:
- Nissan Skyline R32 GTS-T (RB20DET)
- Nissan Skyline R33 GTS-T (RB25DET)
- Nissan Skyline R34 GTT (RB25DET)
AVAILABLE NOW FOR $249.00
HOW CAN YOU PLACE YOUR ORDER?
The answer is simple!
Purchase your new Carbon Airbox online now via our massive new website at http://www.justjap.com for fast Australia-wide delivery.
With Australia's biggest range of High Performance Japanese Parts all under one roof, and all available online, purchasing your tuning parts online couldn't be easier!
Please contact our sales team if you have any questions, or reply here.
R33 GTR?
Not at the moment im afraid, however we will be dummying one of the ECR33 Carbon Airboxes on one of the 5 R33 GTR's we have in stock to see what sort of modification is needed to get them to fit so we are working on having them available for BCNR33 soon.
Cheers,
Steve
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
